Cut Image ⌘ X not functional in TVPaint 11.5
Posted: 05 Dec 2020, 17:07
In TVPaint 11.5 the Mac shortcut ⌘ X for Cut (delete) Image is no longer functional. ⌘C for Copy and ⌘V for Paste , ⌘Z for Undo still work as normal, but ⌘X has been disabled. Please restore ⌘X . (yes, I can use the standard Windows shortcut Ctrl X , but my brain is wired to use the Mac OS shortcuts I'm accustomed to. When I select images and press ⌘X , but nothing happens it is disconcerting and breaks my work flow.
Re: Cut Image ⌘ X not functional in TVPaint 11.5
Posted: 06 Dec 2020, 00:26
by ini
I think it's because default cut & default delete is changed to another name, name with "(Fill gap from right)"
so It seems not assigned on that keys defaultly,
Default cut
"TVPaint Animation : Cut Selection"
is now changed to
"TVPaint Animation : Cut Selection (Fill gap from right)"
We have to assign "TVPaint Animation : Cut Selection (Fill gap from right)" to ⌘ X
I think functions with "(Fill gap from right)", seems better to be omit it, so that we have compatibility with other version.
Posted: 06 Dec 2020, 00:36
by ini
Delete & cut function is now divided to four....
-(Fill gap from right) (previously default)
-(Keep empty)
-(Stay put)
-(Fill gap from left)
Each fuction controls how we maintain other images after delete or cut images
but I think Xavier is making it possible to control this with "lock position" I think.
viewtopic.php?f=10&t=13897&start=15
If we can control these with "lock position", I think we don't need the 4 version of fuction.
Posted: 07 Dec 2020, 00:36
What I'm referring to is the basic Cut Image , Copy Image , Paste Image, Undo , which are shortcuts CTRL X (Cut) , CTRL C (Copy) CTRL V (Paste) , CTRL Z (Undo) on Windows. On Mac the shortcuts are ⌘X (Cut) , ⌘C (Copy) , ⌘V (Paste) , ⌘Z (Undo). In TVPaint 11.5 the shortcuts ⌘C (Copy) , ⌘V (Paste) , ⌘Z (Undo) all work as normal , but ⌘X (Cut) is disabled.
⌘X (Cut) works in previous versions of TVPaint 11 , before 11.5.
This shows it under the Image menu - with the Windows shortcuts :
- Cut_Copy_Paste_Image.jpg (24.37 KiB) Viewed 6690 times
The
User Manual says:
The standard keyboard shortcuts : [Ctrl+X] (cut), [Ctrl+C] (copy), [Ctrl+V] (paste),[Ctrl+A] (select all), [Ctrl+Z] (cancel) are valid in all alphanumeric fields (note that these shortcuts are valid for Windows and Linux.
On Mac computers the user presses the [Cmd] key instead of [Ctrl]).
- Screen Shot 2020-12-06 at 5.51.30 PM.jpg (32.39 KiB) Viewed 6690 times
Posted: 07 Dec 2020, 11:09
by Xavier
OMG ! you're right, something went wrong.
Posted: 07 Dec 2020, 13:58
by ini
oh, I see..!
