How can I grab the color from the current layer ONLY? Topic is solved
Animationriver
Post by Animationriver »
Hello!
This question is very important to me for my work.
I am using an eyedropper in Photoshop. There is a mode for capturing color through all layers.
There is a mode for capturing color from the current layer.
Q:
I WORK in TVpoint 11.5!!!
WHEN ALL LAYERS ARE VISIBLE.
Is it possible to create such an option as in PHOTOSHOP?
I have attached a video:
color.mp4
CURRENT LAYER ONLY
(11.51 MiB) Downloaded 880 times
Re: How can I grab the color from the current layer ONLY?
I agree with you , this would be a useful function to have for the color picker (eyedropper) tool in TVPaint.
The topic should probably be moved to Feature & Improvement requests forum.
You can make a custom button to do this using the following embedded GEORGE script:
tv_GetWidth
Width = result
tv_GetHeight
Height = result
ExitFlag = 0
tv_LockMouse 4
While ExitFlag == 0
     tv_WaitButton
     parse result ButtonState X Y
     IF ButtonState == 3 || ButtonState == 4 || X < 0|| X > Width || Y < 0 || Y > Height
         ExitFlag = 1
     ELSE
          tv_GetPixel X Y
          parse result R G B A
          IF A > 0
               tv_SetAPen R G B A
 //          tv_warn "pixel color = " R G B A
          END
     END
END
tv_UnLockMouse
The button will sample the RGBA value of the current layer/current pixel and set the APen color.
Click RMB to exit. Or if your stylus is setup, hold down the lower switch on the barrel and click the tip.
1st Update to script: you may also just click outside the Project window to exit.
2nd Update to script: added arrow + question mark cursor while selecting layer color reverting to normal cursor on exit.
sven
tribute27
Post by tribute27 »
Svengali wrote: 09 Dec 2020, 19:53 You can make a custom button to do this using the following embedded GEORGE script:
ExitFlag = 0
While ExitFlag == 0
     tv_WaitButton
         ExitFlag = 1
     ELSE
          tv_GetPixel X Y
          IF A > 0
               tv_SetAPen R G B A
          END
     END
END
sven
this is amazing, thank you!
Animationriver
tv_GetWidth
Width = result
tv_GetHeight
Height = result
ExitFlag = 0
tv_LockMouse 4
While ExitFlag == 0
     tv_WaitButton
         ExitFlag = 1
     ELSE
          tv_GetPixel X Y
          IF A > 0
               tv_SetAPen R G B A
          END
     END
END
tv_UnLockMouse
sven
This is genius! Sven!
Thank you!
I made a button on a custom panel. And it works.
When you paint, you want to have such a button on the WACOM ExpressKey.
Or a button on the stylus.
Make it a hotkey.
I can make a hotkey for the eyedropper.
But the eyedropper tool is not your "miracle script button".
How would you do this if you needed to?
I don't know how to do it.
Animationriver wrote: 11 Dec 2020, 00:22 How would you do this if you needed to?
Its easy.
Let's say you named your custom panel "ColorStuff" and in the panel you put your button named "LayerPixPick".
Open the Configure Keyboard Shortcuts panel. In the Search box type "LayerPixPick" which will show you The Custom Panel name... click on "(+) ColorStuff" and select the "LayerPixPick" button name which will highlight.
Pick a shortcut key you want to assign the button to, let's say "Shift P", and OK, to save the Shortcuts list. From there you link Shift P to a button on your device or stylus like it was any other shortcut key.
sven
Animationriver
Svengali wrote: 11 Dec 2020, 03:38
Its easy.
sven
I sincerely thank you for your help and support!
This is a very good job on your part.
Thank you for not leaving me in a difficult situation.
I completely solved my question with your help. :D :D :D :D :D :!:
Animationriver
tv_GetWidth
Width = result
tv_GetHeight
Height = result
ExitFlag = 0
tv_LockMouse 4
While ExitFlag == 0
     tv_WaitButton
         ExitFlag = 1
     ELSE
          tv_GetPixel X Y
          IF A > 0
               tv_SetAPen R G B A
          END
     END
END
tv_UnLockMouse
sven
Hello!
I am very happy to be lucky enough to receive a new tool.
But I have to reset the instrument.
I do a tap outside the picture field, after capturing the color
Do you know how to make an addition to the script. So that after the color is captured, the instrument automatically switches to STROKE [D] mode.
In other words, I want: functionality like a standard eyedropper tool.
Thanks for the opportunity.
Yes, its a small change to make it return to your active tool after choosing a color, with one problem:
If you choose a background pixel (one which has zero alpha value) the color is returned as black.
So, the following script traps when you click on a background pixel or as might happen, you are not on the layer you think you are on.
The script warns that no color was found (instead of making your APen black).
In that case you might have to confirm that you are on the layer you think you are AND/OR click again to sample the color.
Simply replace the other embedded script with the following:
tv_LockMouse 4
tv_WaitButton
tv_GetPixel X Y
tv_UnLockMouse
IF A > 0
    tv_SetAPen R G B A
ELSE
     tv_warn "no pixel color found"
END
sven
Animationriver
Svengali wrote: 13 Dec 2020, 00:59 Yes, its a small change to make it return to your active tool after choosing a color, with one problem:
tv_LockMouse 4
tv_WaitButton
tv_GetPixel X Y
tv_UnLockMouse
IF A > 0
    tv_SetAPen R G B A
ELSE
END
sven
You are my savior!
You are just a genius!
I don't know how you do it!
But I am sincerely grateful to you for your knowledge. And responsiveness!
If I could watch video tutorials on how to write a script. Then I probably would be able to do it and help just like you.
Thank you, sven!
