Another Eraser Bug: Fill Tool forced to "Erase" mode when using Wacom Topic is solved
m-ries
Post by m-ries »
Hello, I am having severe troubles with the fill tool.
While using a mouse it behaves as it should, but as soon as I use my Cintiq (Pro 24, newest Driver) the mode changes from color to erase. Using my Wacom it is impossible to select any other mode, since it immediately switches back to erase. Using my mouse again: Everything fine.
This happens both using the Fill Bucket as well as Filled Stroke.
I am using the latest version of TVP on Mac OS Catalina.
Thanks for your help and best regards!
Matthias
Xavier
Re: Another Eraser Bug: Fill Tool forced to "Erase" mode when using Wacom
Post by Xavier »
Hi, first of all, please open the about dialog : can you see the release date ?
Second question : did you change any setting in the Wacom configuration tool ?
m-ries
Post by m-ries »
Hi Xavier,
thanks for your hint – over the weekend I had some time to breath and read more in the support forum; so I found out that you had been busy and released a new version on December 8.
This fixed my problem!
Previously I just had checked the version number which seemed correct for me and did not expect a new release since I had last updated in november.
Thanks for your work and your help. Stay safe and have a good time over Christmas!
Xavier
Post by Xavier »
Thanks for your feeback. We're glad that you keep supporting us.
