Optical Flow FX with A.I. You can use "A.I. Trains of 4 bit Computer" Algorithms, There's an Article
TheQuestionMark
Post by TheQuestionMark »
I was wondering is it possible modify Optical Flow with A.I.? When you use optical flow the image stays sharp and doesn't blur. You should try and read this article. Maybe M.I.T. can help you with programming the A.I. to work with TVPaint.
https://www.technologyreview.com/2020/1 ... computers/
Re: Optical Flow FX with A.I. "A.I. Trains of 4 bit Computer" Article
The Optical Flow FX is the most interesting of TVPaint's image modification effects. Documentation on its uses and techniques remains limited.
I'm curious to hear how you are using OFFX and how you see A.I. being applied to it?
sven
TheQuestionMark
Svengali wrote: 13 Dec 2020, 17:23 The Optical Flow FX is the most interesting of TVPaint's image modification effects. Documentation on its uses and techniques remains limited.
sven
I just want to fine to turn line by pushing the shape of the the drawing. Also the color layer too. And the A.I. learns to make the remain line layer and color layer remain sharp. If you StyleGAN A.I. the image remains sharp but not blur. But this is not StyleGAN it's just an A.I. image modification to remain images sharp. Theory as you push it auto-applies the correct sharpness of image modification. Or another theory it can also A.I. learn to shed pixels or add pixel image modification. Or you apply both to have seamless image modification line layer and color layer.
