Hi,
I think there must have been mistake. Why is the HD setting default 30 fps when the standard is 24? Btw, all the settings are default to 30fps. Who decided that? Can you make it back to 24fps, pretty please?
Thank you.
11.5.0 HD1080 is 30 fps?
TV Paint 11.5.3 Windows 10
Re: 11.5.0 HD1080 is 30 fps?
Yes, it's been discussed here : viewtopic.php?f=21&t=13934
Before the next release you can edit the file data/pagesize.conf in the TVPaint installation folder.
Thanks for that, I will take a look.
Cheers
Cheers
just to report back, editing the /pagesize.conf did the trick and it is quite elegant solution, I wish it would be documented as a basic pipeline scenario in the manual.
cheers
cheers
Thanks for your feedback
It will be fixed in the 11.5.1
