Page 1 of 2
not detect sensitivity without WinInk
Posted: 22 Dec 2020, 05:50
by OldmanR
So atm it appears I can't have pen sensitivity without turning on 'WindowInk' in wacom preference.
(I'm using rather old tablet that requre rather old driver to run properly).
but if I turn the WindowInk on then I can't do alt+RMB for zooming in and out , anyone having same issue? kinda shame having to run into this after 7 years of having such dependable software.
Re: not detect sensitivity without WinInk
Posted: 22 Dec 2020, 05:57
by OldmanR
Oh, btw I'm using
-Window10
-TVPaint 11.5 64Bit Standard Edition
Posted: 22 Dec 2020, 11:02
by Xavier
is it in TVPaint only ?
Posted: 22 Dec 2020, 14:04
by OldmanR
yes, other software in my PC such as Clipstudio , Blender(GreasePencil) and Photoshop don't have the same issue.
and I made sure to open only one software at a time.
Posted: 22 Dec 2020, 14:29
by Xavier
Ok, please open the about window in TVPaint. Which build date is it ?
Posted: 22 Dec 2020, 17:46
by OldmanR
the version is 11.5.0-64 bits
Posted: 22 Dec 2020, 19:36
OldmanR wrote: ↑22 Dec 2020, 17:46
I think he is asking for the
date of the build . Go to Help Menu > About TVPaint Animation > look at the build date at the top of the window that opens after you click on About TVPaint Animation.
Posted: 22 Dec 2020, 23:23
by Xavier
D.T. Nethery wrote: ↑22 Dec 2020, 19:36
Thanks ! yes, that was actually the question
Posted: 25 Dec 2020, 11:03
by OldmanR
sorry for late reply, the version was from Dec 08 2020.
Posted: 29 Dec 2020, 05:52
by OldmanR
Since its not appear to be any plan on early fixes would it be possible to roll back to older version before december?
Posted: 29 Dec 2020, 11:03
by Dean
Hello, I saw that you turn on Win Ink in the Wacom driver, but have you tried turning it on in the General tab of the Preferences in TVPaint while keeping it unchecked in the Wacom driver?
Posted: 30 Dec 2020, 07:39
by OldmanR
Dean wrote: ↑29 Dec 2020, 11:03
Yes I've tried fumbling with all the option even restart the program every time I made changes in preference, and right now instead of going back and forth in this forum I really need to get work done, is there no way to roll back to older version for now?
Posted: 30 Dec 2020, 11:35
by Dean
I sent it to you via PM
Also, which table model are you using?
Posted: 30 Dec 2020, 11:48
by Xavier
OldmanR wrote: ↑30 Dec 2020, 07:39
So you say that in the older versions it was different ?
Please let us know if it's okay for you with TVPaint 11.0.10. There is maybe something to fix on the 11.5.0.
Posted: 01 Jan 2021, 02:59
by OldmanR
Xavier wrote: ↑30 Dec 2020, 11:48
unfortuntedly the problem still persist, I'm starting to suspect something in Window updates instead.
I'll test it on other pc and keep you guys posted, appreciate helps and support so far.
