Still Problems with Strokes when repeatedly Re-pressing Shortkey with Brushes that's with Texture
TheQuestionMark
Post by TheQuestionMark »
Feels like you only fix part of the problem and but not all of problem. When pressing the shortkey repeatedly as you "Curve" your strokes it travels in a straight line. It should follow on how you actually do you strokes when you curve, not a straight line. Please fix this ASAP.
It's a SUPER SUPER real hassle when you have Brush with Texture and Eraser with Texture.
tv_paper Hardness 39 Invert 1 Size 0.514800 Angle -26.000000 OffsetX 0.000000 OffsetY 0.000000 FlipX 0 FlipY 0 Active 1 Name "/Cement Hard"
Xavier
Re: Still Problems with Strokes when repeatedly Re-pressing Shortkey with Brushes that's with Texture
Post by Xavier »
Could you please attach a screen recording so that we see what happens ?
TheQuestionMark
Xavier wrote: 28 Dec 2020, 09:54 Could you please attach a screen recording so that we see what happen ?
I'm not sure how to display it by post. But there's the link. As you can see when stroke....keep eye on the "Turn ON" flickering Texture Icon from the Main Panel. That's when I keep pressing the shortkey to switch to my brush with texture. It's real hassle when you use Brush with Texture and Eraser with Texture, because it draws as straight line and not curve.....Strokes aren't drawing as intended.
https://drive.google.com/file/d/1CiN9FT ... sp=sharing
Hello, so if I understood correctly, the issue happens when you press the shortcut key to your custom brush while drawing? Just out of curiosityn which keystroke is assigned to it, please?
TheQuestionMark
Dean wrote: 28 Dec 2020, 13:04 Hello, so if I understood correctly, the issue happens when you press the shortcut key to your custom brush while drawing? Just out of curiosityn which keystroke is assigned to it, please?
Any brush with texture, Pencil Tool, Custom Brush Tool. I assign it to C.
"Grab Tool" with Paper, Assign Shortkey, and then do what I show on the Video.
Hello, the same issue seems to appear on my part when doing fast strokes while switching brushes rapidly, it seems that switching brushes while having the pen pressing again the tablet and lifting it can make TVPaint miss some inputs.
TheQuestionMark
Dean wrote: 29 Dec 2020, 12:28 Hello, the same issue seems to appear on my part when doing fast strokes while switching brushes rapidly, it seems that switching brushes while having the pen pressing again the tablet and lifting it can make TVPaint miss some inputs.
Yes, when you need to use texture with brushes. There's no missing inputs when you use brushes with deactivated texture. And I really texture with my brush strokes.
Xavier
Post by Xavier »
TheQuestionMark wrote: 02 Jan 2021, 01:03 Yes, when you need to use texture with brushes. There's no missing inputs when you use brushes with deactivated texture. And I really texture with my brush strokes.
So was this possible with TVP 11.0.10 ?
Maybe a regression... I'll register a bug.
TheQuestionMark
Xavier wrote: 12 Jan 2021, 15:39
The problem was way worser in TVP 11.0.10 and before, I posted it about a very long time ago. The stroke was lagging even with straight strokes.
Xavier
Post by Xavier »
We managed to reproduce it, it's on the list :)
