Copy-Cut-Paste-Delete keyboard shortcuts
Xavier
Post by Xavier »
Due to new shortcut functions, if you upgraded from 11.0 to 11.5 some of your keyboard shortcuts may have been disassigned.
By default, you should have the following key bindings :
- Del --> TVPaint Animation: Delete Selection (Fill gap from right)
- Ctrl X --> TVPaint Animation: Cut Selection (Fill gap from right)
- Ctrl V --> TVPaint Animation: Paste
Just for the info :)
Xavier
Re: Copy-Cut-Paste-Delete keyboard shortcuts
Post by Xavier »
Note about the deletion modes:
- fill gap from left|right --> moves the instances from the left|right in the layer to replace the instances you removed
- keep empty --> erase the content of the instances, do not move
- stay put --> truncate the layer if you remove the instances at the beginning or at the very end, otherwise similar as keep empty
