Hello all!
Just a little quirk I'm experiencing while using the paint bucket tool. It defaults to "erase" and when I change it to "color" it automatically switches back to "erase" when I move the cursor over my drawing area. I use a Cintiq and restored default settings to my pen. Also, this is the only tool I've noticed so far that has this problem.
Anyone else experience this problem? Thanks for any thoughts!
Paint Bucket tool defaulting to "Erase" Topic is solved
Re: Paint Bucket tool defaulting to "Erase"
Before anything --> viewtopic.php?f=10&t=6167
Then could you please go to Help->About, and tell us the build date you see in the about window titlebar ?
Aw, yes! Thanks for the heads up.
So I am using a Cintiq Pro 24 on an iMac (27-inch, late 2013) on version 10.15.7 of Catalina.
The build date is Oct 30, 2020. The title bar reads: TVP Animation 11 WIBU (11.5.0-64 bits) en Oct 30 2020
Thanks for the help!
I think you meant Nov 30 ? Anyway, try downloading again from your account. You are probably using the bad build !
The good one is from Dec. 8, 2020 (my fault, sorry
Wow! The reinstall worked! Thanks so much!
