How to copy and paste properly?
Posted: 22 Jan 2021, 15:16
by Yochay
Hi,
This might seem a ridiculous question, but I couldn't solve it. I want to copy and paste a drawing onto another existing frame, but when I paste it, it doesn't get pasted on the existing frame, but rather on a new separate frame. How do I paste in on the frame I want? Thanks :)
Re: How to copy and paste properly?
Posted: 22 Jan 2021, 15:51
Yochay wrote: 22 Jan 2021, 15:16 Hi,
See: https://www.tvpaint.com/doc/tvp11/index ... side-layer
https://www.tvpaint.com/doc/tvp11/index ... ther-layer
Select an image, then click and drag the image to the frame you want to copy it to , release it. There are three different modes you can choose from as you release the image:
Copy , Insert , Move . Each behaves slightly different. (see the links to the User Manual above and also see the video below).
https://youtu.be/aMnhwTnxV8M
You may also use this click & drag technique to copy or insert images from one layer to another layer.
https://www.youtube.com/watch?v=TMIIyyzQClQ
Using INSERT will add the selected frames to the existing timeline , thereby extending the layer length.
Using COPY will have the selected frames overwrite the existing frames on the timeline , and the layer length will stay the same.
Posted: 04 Feb 2021, 18:58
by schwarzgrau
I always just mark the frame, press CTRL+C, mark another frame and press CTRL+V, while the method David mentions is surely superior I thought I should mention it too
Posted: 10 Jul 2024, 17:46
by onyinyeda
Hey D.T. I found this super helpful but i still do not know how you’re selecting the frame. Are you holding down a key to select the frames?
Ive tried googling this but i cant seem to find the answer.
D.T. Nethery wrote: 22 Jan 2021, 15:51
Posted: 10 Jul 2024, 17:54
by onyinyeda
Never mind. I figured it out 🤦‍♀️
