Pen button eraser
Posted: 04 Feb 2021, 10:50
by Agris
Hey!
Wacom pens has two buttons and I've assigned one of them to work as an eraser. (works same way as using other side of the pen).
When I press the button and touch the surface - eraser works - all good here.
The problem:
I can't find how to modify this eraser, that is activated with this Pen button. Besides this pen button activated eraser I've made two eraser presets : soft and hard - I have assigned keyboard buttons for them. I'd love my soft eraser to be activated with pen button. - Is there a way to do that? At the moment, when I press the button on pen, it enables some random, really big hard eraser.
Another eraser problem is - That "preview" option fir eraser sometimes turns on, although I've turned it off. I've saved my presets with Preview OFF, however, when I restart TVP it's ON again. Reason I turn it off is because if it's on, the first touch with pen to tablet results in FULL pressure eraser blob. When turned off, works as expected.
I'm on Mac OS Catalina , TVP Standard 11.5
Re: Pen button eraser
Posted: 04 Feb 2021, 11:23
by Xavier
Yes, you're right : with the current version of TVPaint there's only one eraser.
With the version 11.5.1 to come (soon) this may be possible, but I'd need to check that.
Could you please tell us a bit more about your setup ? which tablet/pen is it ?
Posted: 04 Feb 2021, 11:59
by Agris
Xavier wrote: 04 Feb 2021, 11:23 Yes, you're right : with the current version of TVPaint there's only one eraser.
Hey, thanks. That's a welcome update :)
I'm using a Wacom Cintiq Pro 24 with a Pro pen 2. (but it's the same with other wacom tablets I guess)
Posted: 04 Feb 2021, 12:33
by Xavier
Agris wrote: 04 Feb 2021, 11:59 I'm using a Wacom Cintiq Pro 24 with a Pro pen 2. (but it's the same with other wacom tablets I guess)
Right now I'm trying to figure out how to configure two different erasers. How did you achieve that ?
Posted: 04 Feb 2021, 12:57
by Agris
Xavier wrote: 04 Feb 2021, 12:33
By creating a Custom panel, then I just grab the tool! :)
After that I map keyboard shortcuts to each of them.
Posted: 04 Feb 2021, 14:14
by Xavier
For the moment, when you change your pen to the eraser (either by flipping it and using the other tip or by clicking a button that activates the eraser) the selected tool changes in TVPaint.
Normal drawing mode:
Capture d’écran_2021-02-04_13-19-50.png (22.72 KiB) Viewed 9176 times
Eraser activated:
Capture d’écran_2021-02-04_13-21-07.png (22.23 KiB) Viewed 9176 times
When the eraser is activated, you can configure the eraser tool with the settings you want, these settings will be remembered.
Posted: 04 Feb 2021, 15:00
by Agris
Xavier wrote: 04 Feb 2021, 14:14 For the moment, when you change your pen to the eraser (either by flipping it and using the other tip or by clicking a button that activates the eraser) the selected tool changes in TVPaint.
Normal drawing mode:Capture d’écran_2021-02-04_13-19-50.png
Eraser activated:Capture d’écran_2021-02-04_13-21-07.png
yess, thanks. It works!
Only thing it doesn't remember is "Preview" switch to be off. But I can live with that :D
Posted: 04 Feb 2021, 16:32
by Xavier
Agris wrote: 04 Feb 2021, 15:00 Only thing it doesn't remember is "Preview" switch to be off. But I can live with that :D
I bet you use the mouse to turn off the checkbox !
As the tool settings are saved per device, try turning it off using your pen.
