Tvp to PSD video layers
condepablo
Post by condepablo »
It would be great to have any way to export a Tvpaint project to a PSD file with the same layer composition.
For those cases when you want to make the clean up or color with photoshop, but you still want to animate in tvpaint
Re: Tvp to PSD video layers
condepablo wrote: 09 Feb 2021, 01:53 It would be great to have any way to export a Tvpaint project to a PSD file with the same layer composition.
Well, for me, the idea of giving up all the ease-of-use in TVPaint to do clean-up in Photoshop sounds like a big step backwards, but if that's something you want to do it seems like it could be feasible , because there already exists the Import script to take TVPaint scenes into Adobe After Effects with the exposures and layering intact. Perhaps some clever person who understands scripting could come up with a method to do this with TVPaint to Photoshop ?
I'm curious what you find to be advantageous about animating in TVPaint , but cleaning-up in Photoshop ? I find the animation timeline in Photoshop very awkward to use compared to TVPaint. For example , there does not seem to be a way to bookmark or image mark (like in TVPaint) only the key frames and flip between only those key frames while skipping all the frames inbetween ? That's an essential feature to draw precise clean-up keys with accurate volume and line quality control. (also, as far as I know, Photoshop has no equivalent to TVPaint's "shift-and-trace" off pegs function) Even the very useful plug-in for Photoshop called 'Animator's Tool Bar Pro' which makes the PS animation timeline somewhat more usable doesn't have that feature. (yet ... I think the creator of Animator's Tool Bar Pro may be trying to add that feature, based on some emails I've exchanged with him)
One reason I can think of for wanting to do clean-up in Photoshop is to take advantage of specific Photoshop brushes. It seems to me that it would be more helpful to be able to import PS brushes to TVPaint (or have a reliable, easy-to-use method of accurately recreating a PS brush in TVPaint) so if the user wanted a specific sort of line quality that could only be achieved with a specific PS brush, they could use that brush (or a faithful recreation of that brush) in TVPaint. (for example , see: viewtopic.php?f=21&t=14040 )
condepablo
Hi D.T Nethery.
"take advantage of specific Photoshop brushes" thats the reasson. there is no way to make tvpaint work like photoshop when we are talking about brushes. bealive me, I tried.
if you chek the "Kyle´s brush" for example, it has an amazing behaviour. photoshop has dual brushes, and a lot more of propierties than tvpaint.
but for animation of course, its one of the worst.
thats why I would like to mix them and use the best of each soft
condepablo wrote: 09 Feb 2021, 17:55
if you check the "Kyle´s brush" for example
Which one ? (there are hundreds of PS brushes by Kyle Webster) . What's the look to the line quality you're trying to achieve ?
condepablo
I Atacched one frame I made with photoshop, and cant find the same expression in any tvpaint ink brush.
please take a close look, in detail you can see a lot of expresivity in the irregular edges.
an here is a video showing the behavior of some kyle brushes: https://www.dropbox.com/s/q9j3748wg27eq ... s.mkv?dl=0
that is just a quick example. I take the time to explore both tvp and ps, and for far, the photoshop brushes are more powerfuls.
but of course, for animation is the opposite. photoshop is the worst.
thats why, I would like to can work with the best of each soft
This can quite easily be done in TVP with an animated brush. About 10 - 30 frames with blobs in different sizes, animation and rotation set to random, size set to pressure.
I agree this line style can be approximated very well.
But its not necessarily that easy.
There are many ways to approach this, i'd also go for an animbrush i would probably take more frames and connect animation to pressure, but to get the right feel can take a lot of iterations.
condepablo wrote: 11 Feb 2021, 00:04 I Atacched one frame I made with photoshop, and cant find the same expression in any tvpaint ink brush.
Thanks, I understand about the behavior of Kyle's brushes in Photoshop. What I meant was , which specific "Kyle's Brush" are you trying to replicate to get the clean-up line quality you desire ? (what's the name of the brush , which of the brush packs is it found in ?)
The movie you uploaded to Dropbox shows a few different Kyle Webster brushes being tested , but they don't look like the brush used for the image you uploaded. Which of Kyle's brushes did you use for this image ? Maybe if we know which brush it is, we can help you replicate it in TVPaint. I don't know if the export from TVPaint to Photoshop video layers is going to be something you will see any time soon (it all depends on if someone is willing to undertake the task to write a script to do it). I think it is more likely that the line quality you show in your image could be reproduced in a TVPaint custom brush.
Just to be clear: are the breaks in the line part of the behavior of this brush or do the breaks in the line indicate where you stopped and started a new stroke ?
(in other words , when you draw a continuous stroke , does the brush create the breaks in the line at random ?)
Eloise carta - 02.jpg (34.19 KiB) Viewed 20891 times
Which one of Kyle's Brushes (a few shown here) are you using to get the line quality shown above ?
condepablo
Men you are the best!
Here is the brush I use for the clean up: https://www.dropbox.com/s/l2ccdyzf2s7ku ... p.abr?dl=0
(I dont remember his original name in the kyle´s brush pack)
if you explore a little bit you will see how dynamic it is, I tried to create something like that on tvp, but I couldn't. Maybe a more experienced user could.
I stop and started a new stroke.
It would be great to get something similar in tvp so I dont need to use ps for the task, of course!
but still, for other projects it would be nice to have that tvp/psd compatibility.
condepablo wrote: 14 Feb 2021, 21:28
Ok, good, now we know what you want the brush to look like. Also good to know that you're creating the breaks in the line by starting and stopping a stroke (because if that was a characteristic of the brush, to create a random broken line stroke, it could be more difficult to reproduce that behaviour , I think) . Other people here who are more skilled in creating Custom Brushes in TVPaint could look at the brush you uploaded and assess whether it could be replicated in TVPaint.
Have you tried out this one that Chad Essley made called Wiggly Nib ? It has characteristics that are similar to the PS brush you like. Perhaps with some fine-tuning it could get the results you want ?
viewtopic.php?f=11&t=8981&start=15#p82489
Two more posted in that same thread are brushes that Fabrice Debarge made for David Fine , which he named David Fine Ink and David Fine:
viewtopic.php?f=11&t=8981&start=15#p82516
Try downloading those and see if you can get them to do what you want, like the Kyle's ink brush.
I've put together those pens along with a few others I've found over the years on the forum, into a Custom Panel. It's attached if you would like to download it and see if any of these are suitable for your needs. (and you can , of course, adjust them by tweaking the various custom brush parameters.)
condepablo wrote: 14 Feb 2021, 21:28 it would be nice to have that tvp/psd compatibility.
I quite agree , but I think that may be a long-term goal (to import .abr format brushes) for the next version of TVPaint. In the short term with the current TVPaint 11.5 creating new brushes or adapting existing ones like Chad's "Wiggly Nib" might be a solution.
Ink Pens Custom Panel.tvpx
(20.05 MiB) Downloaded 1064 times
Another suggestion for customizing brushes: Experiment with the Profile Editor curve for SIZE. zigzagging the value for multiple Y points along the curve can vary the line thickness in interesting ways based on Pressure.
Profile Size - Y axis.png (20.27 KiB) Viewed 20779 times
sven
condepablo
Hi there! Nethery, thanks a lot for the support. I was doing some test with the brushes you provide, and making some tweaks on the settings and I came with something pretty useful. its not the same, still the ps brush has a more fluid react, but its a excelent alternative to avoid use ps for clean up.
here is what I did with tvp. and share the tvpaint brush.
im very happy, thank you again!
p.d: thanks svengali too for the tip
p.d: by the way, if you are interesting in the project, here is what I have online so far: https://www.artstation.com/condepablo/albums/1847355
a tale for liz brush.tvpx
(529 KiB) Downloaded 898 times
wreckedlemon
Post by wreckedlemon »
condepablo wrote: 09 Feb 2021, 17:55 Hi D.T Nethery.
This would be handy. Maybe a script like the after effects script?
Zig
Desktop: TVP Pro 11.5 Windows 10 with Wacom Cintiq 16 Pro.
Android Tablet: rel. 11.5, Samsung Galaxy Tab S7plus - 256gb. One UI 2 Point something ;)
www.diaryofshortdisturbances.blog
