Drag and Drop option does not work for some reason on Windows 10 :/
Posted: 22 Feb 2021, 17:06
by xayloh
I can import files when I click - import>file select manually. But its too time consuming if I have multiple different images, so Id like to import then right away by dropping them in the workspace area so that I get the import widow.
Can someone tell me what I can do? I have Windows 10 and Tvp 10.5
Re: Drag and Drop option does not work for some reason on Windows 10 :/
Posted: 22 Feb 2021, 17:37
No, you can't use DragnDrop or the clipboard, unfortunately.
I assume your files are all named differently, not following any scheme? In that case you could use a renaming app to change their name to something like image001, image002 and so on, which will be imported by TVP in one go.
Posted: 22 Feb 2021, 18:24
by xayloh
slowtiger wrote: ↑22 Feb 2021, 17:37
Hello, what do you mean clipboard? It worked fine on a laptop a few months ago, when I could drop and drag, the same windows 10 and tvpaint, but it doesnt seem to work on my new PC :/
Posted: 22 Feb 2021, 18:25
by xayloh
I have random names on files, but they are either ending with jpeg or png. It worked fine before to drag and drop, so I wonder if there is some option I can click
Posted: 22 Feb 2021, 18:50
The file extension doesn't matter, only the file name.
Just tested, I can drag'n'drop on Mac, just never used it because TVP at full screen obscures any finder window.
Posted: 23 Feb 2021, 10:20
by Dean
Hello, is your TVPaint 32 bit by any chance? Yesterday I had a user who had a similar problem and using a 64 bit build fixed it, it was on v11, though.
