Color coded layer icons V5 for TVP 11 - 12.0
I was really used to the colors of the layer icons in previous versions of TVPaint so I decided to colorize the current icons with the colors of the older version of TVP
For those who are stuck in the past! V1 03/12/2021
V2 11/12/2021
UPDATED V3 10/10/2022
New TVP 11.7 Icon scaling options
Removed the other outline options for simplicity (they all had a worse visual read anyways)
UPDATED V4 12/2/2022
Added Stencil Icons
Added alpha lock Icons
UPDATED V4.1 03/11/2023
Changed Preserve transparency icon to a CYAN color, the rainbow colors made it hard to identify the icon.
UPDATED V5 06/13/2024
TVP12 Icons added
-Some icons are reused in the GUI for layer controls so most of the icons are simple recolors except for layer visibility.
V2 11/12/2021
Added Stencil Icons
TVP12 Icons added
- Color_Coded_Layer_Icons_v5.zip
- (665.03 KiB) Downloaded 2383 times
TVPaint 11.7.4, 12.0.2
i7-8700k, 48GB, Desktop W10
Re: Color coded layer icons
I like it! Thanks! I didnt even know you can customize the little icons
Re: Color coded layer icons v2
Updated to v2
Re: Color coded layer icons V3 11.0 - 11.7
Updated to v3 for TVP 11.7 update!
Thank you !
- CartoonMonkey
This is an EXCELLENT idea!
Quick upload update v3.1
made 11.5+ dark light folders for consistency
Re: Color coded layer icons V4 11.0 - 11.7
V4 Update, Added more icons
- CartoonMonkey
Absolutely wonderful! TVPaint should adopt these by default. (If you'd let them!)
Agreed !CartoonMonkey wrote: ↑09 Dec 2022, 21:15 Absolutely wonderful! TVPaint should adopt these by default. (If you'd let them!)
I'd love to see them bring back some color coding in a future update for sure!, The icons I made were really quickly made so they'd probably have a better solution than mines.CartoonMonkey wrote: ↑09 Dec 2022, 21:15 Absolutely wonderful! TVPaint should adopt these by default. (If you'd let them!)
I think I went a little too far with the preserve transparency icon, it just does not read very well from afar so I'm thinking of changing it really soon here.
New version is now uploaded!
Re: Color coded layer icons V5 12.0
TVP12 Icons added
TVP12 Icons added
TVP12 update includes new icons, most of which are recolors, except for the layer visibility one.TVPUSER wrote: ↑13 Jun 2024, 22:12 UPDATED V5 06/13/2024
TVP12 Icons added https://eldfall-chronicles.com/
-Some icons are reused in the GUI for layer controls so most of the icons are simple recolors except for layer visibility. https://www.musicanalyticstools.com/
Re: Color coded layer icons V5 for TVP 11 - 12.0
Ah lovely... i forgot about this great source of procrastination potential
