Clicking right mouse button layer transparency
Hi,
I'm new to TVP 11 (long time TVPaint 10 user), so I have another question:
When I want to change the transparency of a layer I used to right click the transparancy and type in a number. This doesn't seem to work anymore. Now I can only use the slider, but it's a bit more difficult to find the exact right number. Is there a way to be able to type the number again?
Thanks!
Thanks!
TVP Pro 11.7.1
TVP Pro 11.7.1
Re: Clicking right mouse button layer transparency
By the way,
I noticed a LOT of functions that are way better in TVP 11 compared to TVP 10.
I love the options at "new layer presets" and the amount of colour labels...
TVP Pro 11.7.1
TVP Pro 11.7.1
I think I have a script somewhere that restores this feature: you click on a button, a popup appears, you type a value and it sets the transparency of the current layer to the value you typed.Joost wrote: ↑26 Mar 2021, 09:06 Hi,
Thanks!
I'll post it as soon as I find it
Thanks!
TVP Pro 11.7.1
TVP Pro 11.7.1
One thing you can do to adjust the slider to a precise percentage if you can't get it by moving the slider is to get it close to the percentage you want , then if you use right mouse click you can adjust it in small increments. So for example, if the slider moves to 50% opacity , but you want 53% , right-click a few times with your mouse to adjust it to precisely the opacity percentage you want.
But I agree , the pop-up window to type in the opacity percentage was a good feature and I'm not sure why it ever went away. If Thierry can find the script he mentioned and posts it here I will be making use of that script. (but I think it would also be worthwhile to restore that feature to TVPaint) .
Thanks for your reaction D.T. Nethery!
I already noticed this. However, when I have to change transparency a lot, this will be a much slower method compared to the TVP 10 method where you just can click, type 30, enter. Done.
Hopefully the script from Thierry will help me out
TVP Pro 11.7.1
TVP Pro 11.7.1
Okay, I've found the script.
I will need to update it a bit, because it changes the transparency on all layers of the current color group and not on the current layer only
I'll change it so it can propose both options
Should be done by Monday or Tuesday.
i can't really script.. but this sort of works
I totally butchered Svens work for it.
This works!
Thanks Peter!
The one thing that wonders me however why since TVP 11 there is always one percent transparency difference between what you type and what the layer shows...
Thanks Peter!
TVP Pro 11.7.1
TVP Pro 11.7.1
Cool,
yeah noticed that too, might be a rounding error?
Another bug in layer opacity control:
When right clicking next to the slider, you always have to click twice or three times for the value to increase 1. This is already unintuitive and unwanted initself
But then when decreasing the value (rightclicking left of the slider) it works but when increasing (rightclicking to the right of the slider) it stops working after some clicks!?
i think the idea to "increase cursor sensitivity 10x while holding shift" would also be very welcome here.
A bit late to the party, but here's the script I talked about: viewtopic.php?f=11&t=14244
Thank you for the script. (and also thanks to Peter for the modified Svengali script above).Thierry wrote: ↑09 Apr 2021, 15:10 A bit late to the party, but here's the script I talked about: viewtopic.php?f=11&t=14244![]()
But I will rename the script from "Set Transparency" to "Set Layer Opacity".
Maybe this is my OCD kicking in , but it makes me notice a little naming inconsistency in TVPaint. If you hover your mouse over the slider which adjusts the percentage of the layer's opacity , the Tool Tip tells you that this slider is to modify the layer's "density". At other times in the User Manual we find this referred to as "opacity". I think for consistency it should be one of those terms (opacity ... or transparency ... or density) but not all three terms used at various times to refer to the same thing. I would not favor density ... I think most people who work with digital art applications would usually refer to the "opacity" of a layer rather than the "density" of a layer. I suppose density and opacity can be considered equivalent , so it's not likely to confuse anyone , but a quick check of other drawing and animation apps I have on my computer -- Photoshop, Sketchbook, ArtRage , Harmony , After Effects, Adobe Animate -- shows that all of those other apps using the term Opacity with reference to layers. So I would vote for using the term Opacity rather than Density (or Transparency).
"Transparency" applied to a layer is almost always with reference to locking/preserving the transparent pixels on the layer.
