Is there a quick way to export an image sequence from every layer without having to select and export every layer manually?
I was counting on the JSON script but it turns out that this does not support the repeat image feature, so I'm looking for another option.
Thanks in advance!
Is there a way to automatically export layers separately?
Re: Is there a way to automatically export layers separately?
Hello Jacky, exporting a CSV file + PNG sequences for the layers, with these settings, should allow you to keep all the redundant images in the project.
- TVPaint_Animation_11.5_Pro_(64bits)_Stallionguyp8iXJEk.png (53.2 KiB) Viewed 3867 times
