Disable ctrl+draw Topic is solved
cwellems
Disable ctrl+draw
Post by cwellems »
When ctrl is held while drawing, the timeline plays and brushstrokes will be made over many frames over time. Is there a way to disable this? I frequently trigger it accidentally while drawing and using ctrl+ shortcuts. Sometimes I don't notice when it happens then I manually have to erase the extra lines from many drawings.
Re: Disable ctrl+draw
cwellems wrote: 07 Apr 2021, 21:33 When ctrl is held while drawing, the timeline plays and brushstrokes will be made over many frames over time. Is there a way to disable this? I frequently trigger it accidentally while drawing and using ctrl+ shortcuts. Sometimes I don't notice when it happens then I manually have to erase the extra lines from many drawings.
In Preferences > General. Uncheck Stroke Animator.
uncheck stroke animator.jpg (95.02 KiB) Viewed 5954 times
cwellems
Post by cwellems »
Thank you!
