BUG: TVPaint 11.5.1 crashes on PNG import Topic is solved
Soom
Post by Soom »
Mac OS High Sierra
I get constant crashes when trying to import PNG images. Sometimes it does import, but as soon as I try to work on it, it crashes anyway. Will try rolling back a version...
Re: BUG: TVPaint 11.5.1 crashes on PNG import
Just guessing here:
- check PNG file names: any non-ASCII characters?
- check path for same
- check bit depth
Soom
Post by Soom »
nope - the PNGs are the same old PNGs that imported perfectly in all previous versions, nothing changed, and I am always using just normal Latin characters )
BUT - after running Onyx and clearing some cache and fonts, restarting into Safe mode and then back to normal, it all works fine now. technology - go figure. I hope it stays that way! :)
Xavier
Post by Xavier »
Indeed, it's not always TVPaint :wink: :P
