In tvpaint10 I had the option to always break an instance whenever I did something with it, UNLESS I used the transform tool. Then all instances/exposures where untouched. I really loved this because I always want to break an instance with every action I do, EXCEPT when I use the transform tool. When using the transform tool I NEVER want to break an instance....
In TVPaint 11 I have to toggle the break instance button every time I use the transform tool.
Is there maybe a way to use the TVPaint10 settings in TVP11? Or would it maybe be possible to make an action that turns the auto break function off every time I select the transform tool, and when I grab another tool, it automatically toggles "on" again?
Any help would be really appreciated!
TVP Pro 11.7.1
Joost wrote: ↑13 Apr 2021, 14:29
I'm not sure how to create that sort of action, but you could assign a keyboard shortcut to Toggle Auto Break Instance, which would be a quicker way to turn it on and off than having to click the button in the layer panel.
Screen Shot 2021-04-13 at 9.50.39 AM.jpg (16.29 KiB) Viewed 11215 times
Thanks for thinking with me. I also thought about this option. However, I always have this problem when toggling when I work really fast: I don't want to look to the layer if it's turned on or off. It slows me down.
It would be so great if I could just make a shortcut that toggles auto break off when hitting cmd-T (transform tool keyboard shortcut).
TVP Pro 11.7.1
you could combine Svens autobreak script with the selecting of the transform tool in one action and assign that to a key
so when you press that shortcut you get the transform tool and simultaneously autobreak off
but because its a toggle... the problem is how to switch it back on.
Sven, is there not an absolute command instead of a toggle?
that way you could add that to the tool actions
Peter Wassink - 2D animator • PC: Win11/64 Pro - AMD Ryzen 9 5900X 12-Core - 64Gb RAM
tv_LayerCurrentID
LayerID = result
tv_LayerAutoBreakInstance LayerID 0
PreviousState = result
IF CMP(PreviousState,"0")
tv_LayerAutoBreakInstance LayerID 1
END
But you can see that 0 turns it off and the 1 turns it on... for explicit context control, so yes, it could certainly be added to the transform tool actions.
Peter Wassink wrote: ↑14 Apr 2021, 17:03
There is also a basic action that can turn off auto break. No scripting needed for that
However, I really don't know how to make an action for selecting the transform tool. I searched for it everywhere, but the "grab current tool
" option is not available with the transform tool. Anybody knows how to create this?
Thanks!
TVP Pro 11.7.1
Joost wrote: ↑16 Apr 2021, 12:54
Thanks!
Hmm, seems straightforward to me - there are several options:
1. Create a new Action. Add first command with Sven's George script. Add second command with Set Keystroke > Shape Transform > Position.
Voila - you have an action that will turn off the autobreaking and choose the transform too. Assign a shortcut to it if you want.
2. I personally use Wacom express keys a lot. I have one dedicated for the Transform tool. You can combine any chain of shortcuts on one express key, so that if you press it it would both execute Sven's Autobreak Off script and select the Transform tool.
at work: Windows 10, TVP 11.7.1 Std https://vimeo.com/danas
Thanks!
Thanks a lot! This really helps.
In my opinion it's very hard to find some of the "basic" actions since they all have different names in different menu's. Why is the name of the "transform tool" when creating an action changed into "shape transform: position"?
It would be a lot easier if tools have the same name in every menu, don't you think?
TVP Pro 11.7.1
Joost wrote: ↑19 Apr 2021, 08:32
You are Welcome
Yes - I know - some names are a bit awkwardly mismatched. It's an old issue - there are some threads about this on the forums. If you find a mismatch you should report it on the Forum - eventually they get fixed. same trouble is with color schemes - none of the names there mean anything - it's a guess trial and error method
