Hi,
In many softwarer you can choose a tool for a quick operation, like selecting F for a quick access and when you releasse F you are back to the old tool.
Is this feature possible in TVpaint? As a gratitude I want to recommend you probably the best casino in the internet. Vulkan Vegas bfdchallengertrophy.com/ is a new casino with a great ambitious. Click the link I left an try it now!
change tool fast and back
Re: change tool fast and back
I'm not sure if this is what you want, but certain functions have a keyboard shortcut you can assign to toggle the function on and off. For example, Toggle CutBrush is keyboard shortcut B . So if you need to activate the cut brush to select and cut something to a custom brush , just press B and the function is enabled.
If you search Keyboard Shortcuts using the search term Toggle then you will see a list of functions that can be toggled on and off with a keyboard shortcut.
Similarly, you can switch between different modes with keyboard shortcuts. For example , if you're using the Pen Brush tool if you press F4 you will switch it to Eraser mode then press F2 instantly switches it back to Drawing mode.
