Any way to get a shortcut for Stopwatch start/stop?
Soom
Post by Soom »
trying to use the stopwatch, but without a dedicated keyboard shortcut it's not so useful... I cannot find any shortcut that would control the stopwatch. is there a way to add it?
thanks
Re: Any way to get a shortcut for Stopwatch start/stop?
Hmmm...
You're right, there aren't enough shortcuts for the Stopwatch:
I'll see what we can do for 11.5.2. In the meantime, I'll add it to the list :)
+1!
Soom
Post by Soom »
Thierry wrote: 28 Apr 2021, 15:52 Hmmm...
thanks!
tanglangxia
Post by tanglangxia »
Hope to add it to the George script too, because there is not much control of the stopwatch here, thanks
Soom
Post by Soom »
the ultimate solution :)
Xavier
Post by Xavier »
Soom wrote: 28 Apr 2021, 15:47 trying to use the stopwatch, but without a dedicated keyboard shortcut it's not so useful... I cannot find any shortcut that would control the stopwatch. is there a way to add it?
thanks
If we were to add them, which shortcuts would you like to have ?
Soom
Post by Soom »
Xavier wrote: 21 Jan 2022, 12:58
thanks
Start/Pause (it should be one button!) and Reset are a must!
Xavier
Post by Xavier »
Ok, and I think that at "show and start" would be welcome too :)
tanglangxia
It is best to join the generated bookmark, blank frame and other functions, it is best to join into the George script, because I want to control the rhythm through the stopwatch, then directly frame number to generate the corresponding time length without need to utilize Generate a bookmark, then match the bookmark, you need to operate a few steps to achieve the required effect, if you join the George script, there is hope one key implementation
