Is it possible to change location of config folder?
Posted: 29 May 2021, 21:08
by spyderheart
Hi all,
For reasons I won't go into - I need to store my config folder somewhere outside the usual location.
When TVPaint starts up it seems to look inside the following folder:
"C:\Users\David\AppData\Roaming\tvp animation 11"
There is a file there called "settings.ini" which points to the desired subfolder that contains all my brushes, scripts, etc.... Usually it looks like this:
[system]
config=default
I know that I can change "default" to something like "my_config" and TVPaint it will look for or create a "my_config" folder to use as the config.
However, when I try changing the value "default" to a folder path elsewhere on my system, TVPaint won't start up.
Does the config folder need to always be in"C:\Users\David\AppData\Roaming\tvp animation 11" next to "settings.ini" or should I be able to change the location to anywhere on my machine by editing the settings.ini file?
If not, this is a feature request for custom config location :)
Thanks,
David
Re: Is it possible to change location of config folder?
Posted: 01 Jun 2021, 10:37
by Xavier
Open TVPaint preferences, then go to the Startup tab. Change the "startup configuration" to "open startup panel", then restart TVPaint.
Capture d’écran_2021-06-01_10-31-17.png (20.18 KiB) Viewed 12566 times
At startup you should have this tiny panel that lets you choose your config location :
Capture d’écran_2021-06-01_10-34-27.png (51.57 KiB) Viewed 12566 times
Posted: 01 Jun 2021, 10:40
by Xavier
Well that's how I assumed it should work ... but this panel doesn't seem very accurate.
Posted: 01 Jun 2021, 15:28
by spyderheart
Xavier wrote: 01 Jun 2021, 10:40 Well that's how I assumed it should work ... but this panel doesn't seem very accurate.
What's not accurate about it?
In any case, this is what I see:
Screenshot 2021-06-01 092248.png (31.58 KiB) Viewed 12539 times
Is it a pro only feature?
Posted: 01 Jun 2021, 17:44
by Xavier
spyderheart wrote: 01 Jun 2021, 15:28 Is it a pro only feature?
Yes you're right, sorry: I checked the code and it's available on pro versions only.
spyderheart wrote: 01 Jun 2021, 15:28 What's not accurate about it?
I mean that it doesn't seem to relocate your config folder anyway.
Posted: 01 Jun 2021, 20:32
by spyderheart
Oh well...
Thank you for looking into it.
