Did TVP11 loose the flipbook function? Topic is solved
BinaryD00D
Post by BinaryD00D »
One thing I really like in TVP10 was the shortcut to quickly flip through the 24 frames im in in a short play. I can't seem to find this shortcut in 11.5... is this supposed to be missing? Or it simply has a different name than last time?
Sorry for asking, it was just sort of part of my work habit...
Thank you.
Re: Did TVP11 loose the flipbook function?
Hello, the flip feature is still available indeed. The shortcut assigned to default flipping is W in v11. But you can still create a variety of alternative flips, each with its own shortcut!
https://www.tvpaint.com/doc/tvp11/index ... esentation
BinaryD00D
Dean wrote: 12 Jul 2021, 12:40 Hello, the flip feature is still available indeed. The shortcut assigned to default flipping is W in v11. But you can still create a variety of alternative flips, each with its own shortcut!
Thank you for the response, this has been informative. Haven't realized the overhaul on the flips. Took me a while to get it the same way as I had it in 10 but it is okay now.
Zane
Post by Zane »
hello, any instruction to set a flip like v10 does? I've tried to set a Directional Flip with Limit Left & Right both 12 and Loop Between Limits checked, which is quite close to v10's flip, but I found it not quite the same because the flip only starts going when I long pressed the shortcut... in v10 you can just press one time and flip will be going, in v11 you have to wait for the flip to go... So is there any setting I can do ?
