Import Multilayer PSD
I try to import a multilayer PSD file in TVP, it imports it, but only as a single layer. I merged the groups in Photoshop and removed the guidelines, to see if this could be the problem, but I still only get the whole PSD merged into one single layer in TVP. Do I miss something?
Xavier
Re: Import Multilayer PSD
Post by Xavier »
Well the PSD format belongs to Adobe, so they change its specification as they wish ...
So far, a PSD that was exported by TVPaint would reopen with all its layers.
If you use the "save as" menu in Photoshop, can you change the format options ?
Check "maximize compatibility" when you save from PS and test itf the problem persists.
Xavier wrote: 13 Aug 2021, 13:37 Well the PSD format belongs to Adobe, so they change its specification as they wish ...
Unfortunately you don't get any options when you save a PSD from photoshop. Could you try to open a recent PSD file in TVPaint? Maybe I'm just doing something the wrong way.
slowtiger wrote: 13 Aug 2021, 13:57 Check "maximize compatibility" when you save from PS and test itf the problem persists.
Unfortunately it was already checken, I usually keep it checken, since I often need to import PSDs in other applications.
schwarzgrau wrote: 13 Aug 2021, 14:46 Could you try to open a recent PSD file in TVPaint? Maybe I'm just doing something the wrong way.
On my end I tested it with a recent PSD file (created in Adobe Photoshop 2021 , Release 22.3.1). The PSD file opens as expected in TVPaint 11.5.2, with all layers intact. (same as always,Groups folders are not preserved and not all blending modes are preserved because of how PS and TVP handle blending modes differently). I'm on Mac OS Mojave 10.14.6.
Thank you for testing David. Good to know it is possible, than I maybe need to try some things on my end to make it work.
NathanOtano
Post by NathanOtano »
Have you tried flattening each layer and its effects to be sure you have only layers with pixels and nothing more?
Yea, there are just plain layers. No groups, effects, guide layers or channels.
NathanOtano
hellofilms
Post by hellofilms »
I don't have TVpaint now to test but I remeber it was a difference if you imported the PSD as an image or if you just opended it as a file. Have you tested to open it as a file?
Windows 11 - TVpaint Pro 11.7.5 & 12.0.4 .- Wacom cintique 24 Pro - wacom driver 6.4.9-2
hellofilms wrote: 14 Aug 2021, 07:43 I don't have TVpaint now to test but I remember it was a difference if you imported the PSD as an image or if you just opended it as a file. Have you tested to open it as a file?
I get the same results whether I open the PSD from the File menu > Open/Import or if I drag and drop the PSD onto the TVPaint interface. Both ways open the PSD as a new project with the layers intact , not merged to a single layer.
Xavier
Post by Xavier »
Would you mind sharing a sample file, to help us reproducing your issue ? I don't have Photoshop installed (and I'm on Linux). Thanks !
Oh sure. Here you go.
examplePSD.zip
(17.32 MiB) Downloaded 951 times
hellofilms wrote: 14 Aug 2021, 07:43 I don't have TVpaint now to test but I remeber it was a difference if you imported the PSD as an image or if you just opended it as a file. Have you tested to open it as a file?
How would you do that?
Xavier
Post by Xavier »
schwarzgrau wrote: 19 Aug 2021, 14:51 Oh sure. Here you go.
examplePSD.zip
Indeed: in TVPaint one single layer; in GIMP many.
Then I saved from GIMP and reopened from TVPaint, and now it's okay (though the file lost half of its size) :
00 Tuerspalt2 v05.psd.zip
(4.75 MiB) Downloaded 843 times
