Saving project in quicktime compressed format?
NathanOtano
Post by NathanOtano »
Hey :)
There is no tv_savemode to save in a quicktime compressed format right? Is it something not too hard to implement? It's the lightest video format in tvpaint that we use for review and I can't find a way to export it with george
Re: Saving project in quicktime compressed format?
There isn't indeed, because the way we export in mov/mp4 is different from the other formats (due to some FFmpeg licensing rights).
It is stil on our radar to allow George export for those formats, but it won't be for 11.5.3.
NathanOtano
Ok thanks :)
Hironori Takagi
Post by Hironori Takagi »
NathanOtano wrote: 03 Sep 2021, 17:11 Hey :)
Earlier I asked Thierry about this and was told that it was difficult to specify some types of compression.
(Although we can select directly on the export screen ...)
I will attach the source file of my custom panel for reference.
ExportMOV_useCN_190719.grg
(3.66 KiB) Downloaded 614 times
NathanOtano
Does your geroge script exports in the quicktime compressed format? I'm not sure to understand your post sorry :)
Hironori Takagi
My post is
・ .mov (ffmpeg) can be selected.
・ However, Prores / mpeg-4 / PNG cannot be selected. (keep the previous state only.)
It was the above intention.
Sorry for the lack of words (maybe due to automatic translation).
NathanOtano
No problem for the translation, I'm already so glad you come to help on the english forum!
Your script is greatly appreciated, i understand now and it helps me understand the problem I had
Best,
jeremyb
Post by jeremyb »
Hi,
On windows 10 (10.0.19044 Build 19044) and tvpaint (11.5.3-64bit dec 3 2021) isn't working.
tv_FirstImage
FrameStart = result
tv_LastImage
FrameEnd = result
tv_SaveMode "Mode=1015"
tv_LockDisplay "Export Mov..."
tv_ProjectSaveSequence playblastPath FrameStart FrameEnd
tv_UnLockDisplay
There is another way to export MOV ?
WINDOWS 10 : 10.0.19044 Build 19044
TVPAINT : 11.5.3-64bit dec 3 2021
CPU : i9-9900
RAM : 64Go
CG: RTX 2080 SUPER 8go
Hironori Takagi
I don't know why, but in the script I wrote
tv_SaveMode "Mode = 1015"
after,
tv_SaveMode
It worked when I added.
Again, I don't know why.
Xavier
Post by Xavier »
Hironori Takagi wrote: 27 Jan 2022, 08:24 tv_SaveMode "Mode = 1015"
Have you been told by someone to do this ?
When trying to match the command result in the code, 1015 seems to activate the external saver aka FFmpeg.
You may try to use Mode=1010 instead, which would in theory activate the internal QT saver.
jeremyb
Post by jeremyb »
Hironori Takagi wrote: 27 Jan 2022, 08:24 I don't know why, but in the script I wrote
after,
tv_SaveMode
Exactly, is working now !
thanks
CPU : i9-9900
RAM : 64Go
jeremyb
Post by jeremyb »
If i want to transpose this export settings
to george code, should be :
FUNCTION exportMp4()
    tv_LockDisplay "Export..."
    tv_SaveMode
    tv_SaveMode "Mode=1016"
    tv_SaveMode
    tv_ProjectSaveSequence playblastPath frameIn frameOut
    tv_UnLockDisplay
END
In other way, tv_ProjectSaveSequence equal to Export Footage > Clip:Display ?
regards,
CPU : i9-9900
RAM : 64Go
NathanOtano
good news :)
jeremyb
Post by jeremyb »
hum, not at all...still a question...because if i run this script i've got en .mov but is totaly white or black with NaN value...
same with mode=1015
CPU : i9-9900
RAM : 64Go
NathanOtano
argh T_T
Have you tried =1010 like xavier suggested?
