Instance clear (tv_Clear) bug when using minus frames on the timeline
Hironori Takagi
Post by Hironori Takagi »
I reporte a bug when we created a custom panel in our studio that "creates an empty instance and names it instance name 0".
-When using a minus frame on the timeline, if the instance is cleared with an empty frame (tv_Clear command or manually layer: clear), the length of the previous instance is not correct.
The importance is not so high, but please consider it.
Re: Instance clear (tv_Clear) bug when using minus frames on the timeline
Hello Takagi-san,
I have tried to reproduce this bug on my side (both 11.5.2 public build, and 11.5.3 beta build) and I wasn't able to do so.
Can you record a small video so we can have more information?
Hironori Takagi
Thierry wrote: 23 Sep 2021, 14:55 Hello Takagi-san,
Okay, Thierry.
I recorded the occurrence of this bug on a video.
210924_to_Thierry.mp4
(2.65 MiB) Downloaded 759 times
Thank you for the video, we managed to reproduce it.
I'll add it to the list (but I cannot guarantee it will be fixed for v11.5.3).
Hironori Takagi
Thierry wrote: 24 Sep 2021, 10:16 Thank you for the video, we managed to reproduce it.
Alright, I wait for your fix.
Thanks.
This should be fixed in v11.5.3.
Hironori Takagi
I got it.
Hello Takagi-san,
We found out that our fix for the issue was causing some unexpected problems elsewhere in the software.
So we decided to revert the fix, as such the issue will not be fixed in v11.5.3, and we'll try to do it for the next update.
Generally speaking, I would strongly advise not to use negative images.
Hironori Takagi
I checked.
Unfortunately, there are cases where a minus frame is used, such as when the clip starts in the middle of walking.
I will tell you in advance.
