tv_writetextfile without dialog
tokejepsen
Post by tokejepsen »
Hey,
I was wondering whether its possible to run the george command "tv_writetextfile" without the permission dialog appearing and blocking execution?
Re: tv_writetextfile without dialog
Hi tokejepsen,
There is an option in the Preferences > Interface panel named "George Alert: tv_WriteTextFile" that can prevent the permission dialog from appearing.
Bram Vermaas
Post by Bram Vermaas »
Hi tokejepsen,
I'm a bit late to the party, but just in case you are still curious.
As a way of automatically giving writetextfile permission:
The preference setting that Thierry mentions is stored in a config.ini file as the line: georgecanwritefiledisplaypopup=1
The config file can be found here (tested for TVPaint 11):
windows: %USERPROFILE%\AppData\Roaming\tvp animation <version> pro\default\config.ini
linux: ~/.tvp/tvp animation <version> pro/default/config.ini
jeremyb
Post by jeremyb »
Hi,
i've got same issue here.
No matter what, checked or not, after restart tvpaint checkbox always checked.
if i modify
config.ini
after close tvpaint, file is reset and i lost modification.
There is no other way, to uncheck this box ?
WINDOWS 10 : 10.0.19044 Build 19044
TVPAINT : 11.5.3-64bit dec 3 2021
CPU : i9-9900
RAM : 64Go
CG: RTX 2080 SUPER 8go
jeremyb
Post by jeremyb »
Okay,
switching back to keep always [...] and Open [...], seems to reset somethings...because is working
CPU : i9-9900
RAM : 64Go
