Hi,
I'm trying to render a 4k png sequence with alpha, compression set to 10 - which means there's no compression - yeah?
Currently it's taking about an hour to render 2000 frames. This seems a bit sluggish to me. Is there anything I might be doing wrong, or that I can do to speed things up?
Rendering image sequence
http://www.daninski.com
Re: Rendering image sequence
Sounds perfectly normal, 2000 frames would be nearly 1 and a half minutes, even in HD this would be 30 minutes at my place.
Really? I'm sure I've had faster. It's not doing any composition. these are single layer renders.
This is how PNG export from TVPaint was explained to me:
PNG is not a compressed format. When you set it to "10", you lower the file size, without affecting the quality. If you set it to "1" it is the same image quality , but it exports very fast , and the file size is larger. "10" exports slowly , but the file size is smaller. If your goal is to get the PNG file sizes as small as possible , use a setting between 6 - 10 . If it doesn't matter if the PNG file sizes are larger then use a setting between 1 - 5 for faster export.
Not entirely correct,D.T. Nethery wrote: ↑04 Nov 2021, 15:19 This is how PNG export from TVPaint was explained to me:
To be exact, PNG is a compressed format, but as you explain the amount of compression can be set and a higher compression value (making the file smaller) results in a slower export, but it is lossless compression.
"Compression" relates to filesize and "Loss" relates to image quality. so PNG has the best of both.
Yes, that's better, to say PNG is lossless , but it does have a compression. FAST export makes for a larger file size , SLOW export makes a smaller file size, but the quality is the same , because it is a lossless format. (I honestly have no real idea how it all works !)
haha... yes the Wikipedia page also goes mostly over my head, but i did just now pick up a funny fact from it ...about where the letters PNG stand for:
the makers of the PNG format intended to create a replacement for GIF because gif was patented and the owner, Unisys, wanted to charge royalties.the PING name, eventually becoming PNG, a recursive acronym meaning PING is not GIF
