Page 1 of 2
Dot appears at beginning of brush strokes?
Posted: 19 Nov 2021, 13:17
by ttrangmar
Hey all, been having this issue for a while now and I'm stumped.
Whenever I use the brush tool to draw, every other line starts with a small half-opacity circle. I've attached an image of whats going on below.
I don't know why this is happening and have tried various methods to get it to stop including restarting pc, restarting wacom, fiddling with pen settings etc.
I have to keep going back through my lineart in order to clean up the lines by erasing them manually.
Any tips?
Re: Dot appears at beginning of brush strokes?
Posted: 23 Nov 2021, 12:01
by Matthieu
Could you please tell me which TVPaint version you're using? I would also need to know your operating system as well as your graphics tablet model and drivers version.
Also, are you using a custom brush? If so, sharing it with me within a .tvpx custom panel would help.
Posted: 24 Nov 2021, 14:03
by ttrangmar
Matthieu wrote: 23 Nov 2021, 12:01 Hello,
Hi Matthieu,
I'm using TVPaint Animation 11 Pro STD (11.5.1-64bits)
My Tablet is a Cintiq 13 screen tablet, Wacom, driver version is 6.3.44-3.
I use Windows 10 currently, and I'm using the standard pencil brush.
Posted: 24 Nov 2021, 16:08
by Xavier
Hi, same as here I think : viewtopic.php?f=10&t=14692
We need the time to figure out, if it's related to the Wacom hardware/drivers and if we can workaround this in TVPaint.
Posted: 25 Nov 2021, 10:52
by Matthieu
Hi ttrangmar,
Thank you for this information.
Could you please try to reset your Wacom driver's pressure profile settings, like Gerhard did in the above topic mentioned by Xavier?
Let us know if this changes anything.
Posted: 25 Nov 2021, 13:40
by ttrangmar
Matthieu wrote: 25 Nov 2021, 10:52 Hi ttrangmar,
Hey all,
I reset the wacom tablet pressure and it didn't fix it, however it does stop if I change the pen's pressure profile directly in TVPaint. However this messed up the brush quality as I adjusted it to get specific pen tip.
Posted: 25 Nov 2021, 13:49
by ttrangmar
I tell a lie- it was a temporary fix, and has since returned to making the little dot again.
Posted: 25 Nov 2021, 14:05
by Xavier
d'oh !!!
Posted: 27 Nov 2021, 13:58
by ttrangmar
Xavier wrote: 25 Nov 2021, 14:05d'oh !!!
I'm still having this issue and there doesn't seem to be any change in how frequently its showing up, any other suggestions?
Posted: 27 Nov 2021, 17:18
Does it happen with every brush tool, or only with some?
Posted: 27 Nov 2021, 20:08
by ttrangmar
slowtiger wrote: 27 Nov 2021, 17:18 Does it happen with every brush tool, or only with some?
From what I can tell, only the pencil tool causes this issue.
Posted: 29 Nov 2021, 12:25
by Dean
Is it the default pencil tool or another custom made one?
Posted: 03 Dec 2021, 11:28
by ttrangmar
Its the standard pencil brush with a minor adjustment to the pressure curve.
Posted: 03 Dec 2021, 12:20
by Dean
Would it be possible to export it as a new tool and send me the TVPX?
Posted: 11 Jan 2022, 14:11
by ttrangmar
I've attached a TVPX file to this post.
