Shortcuts with new update
acrookedheart
Post by acrookedheart »
I'm sorry if this is a duplicate question. I did try the search box first.
With updating to 11.5.3, has anyone else lost all their shortcuts? Mine went back to default and when I loaded a saved shortcut file, the left was blank minus a few that said no shortcuts available.
After Update
After previous saved shortcut loaded.
Xavier
Re: Shortcuts with new update
Post by Xavier »
acrookedheart wrote: 03 Dec 2021, 19:27 I'm sorry if this is a duplicate question. I did try the search box first.
Hi, sorry for the delay ! on which operating system does it happen ?
would you mind sharing your shortcut file ?
acrookedheart
Windows 64
It won't let me attach a .txt file.
I'll attach a zip as well as the content.
For the email, I removed the =none lines and left only the shortcuts in play.
Shortcuts
"A" = Zoom: Shake
"B" = Shape: Filled Stroke
"C" = Brush: Rotate
"D" = Shape: Stroke
"E" = Drawing Mode: 03 (Erase)
"F" = Shape: Paint bucket
"H" = Layer: Split
"I" = Project: Clip: Append Images
"J" = Tools: Custom Brush Stamp in Place
"K" = Brush: Resize
"L" = Shape Select: Cut To New Layer
"M" = Zoom: New Zoom window
"N" = Color: Invert A/B
"O" = Brush: Outline
"P" = Interface: Toggle Color Panel
"Q" = Zoom: Out
"R" = Drawing Mode: 01 (Color)
"S" = Shape: Dots
"T" = Drawing Mode: 01 (Color)
"U" = Undo: Last Action
"V" = Shape Transform: Panning
"W" = Zoom: In
"X" = Brush: Flip Horizontally
"Y" = Brush: Flip Vertically
"Z" = Tools Option: Change size
"Shift A" = Interface: Toggle Tools Panel
"Shift B" = Layer: Toggle Background Mode
"Shift C" = Tools Healing: Set
"Shift D" = Interface: Open Preferences Panel
"Shift E" = Tools Option: Get Previous Tool
"Shift F" = Layer: Go to Image
"Shift G" = none
"Shift H" = Brush: Double Size
"Shift I" = Project: Clip: Insert Images
"Shift J" = Spare: Copy To
"Shift K" = Layer: Clear
"Shift L" = File Project: Open
"Shift M" = none
"Shift N" = File Project: New
"Shift O" = Brush: Toggle Handle Corner
"Shift P" = Tools Pantograph: Set
"Shift Q" = TVPaint Animation: Quit
"Shift R" = Shape: Rectangle Fill
"Shift S" = File Project: Save
"Shift U" = Undo: Multi Redo
"Shift V" = Zoom: Show full page
"Shift W" = File Project: Close
"Shift X" = Brush: Double Width
"Shift Y" = Undo: Multi Redo
"Shift Z" = Brush: Rotate 90°
"Ctrl A" = TVPaint Animation: Select All
"Ctrl C" = TVPaint Animation: Copy Selection
"Ctrl D" = Shape Select: Clear
"Ctrl E" = Layer: Merge Selected
"Ctrl F" = TVPaint Animation: Search...
"Ctrl K" = Interface: Configure Keyboard
"Ctrl L" = Layer: Light Table Mode
"Ctrl N" = Layer Preset:Anim Layer
"Ctrl O" = File Project: Open
"Ctrl P" = Printer: Print
"Ctrl S" = File Project: Save
"Ctrl T" = Shape Transform: Position
"Ctrl V" = TVPaint Animation: Paste
"Ctrl W" = Interface: Close Window
"Ctrl X" = TVPaint Animation: Cut Selection
"Ctrl Y" = Brush: Flip Vertically
"Ctrl Z" = Undo: Last Action
"Ctrl Shift E" = File Export: Sequence
"Ctrl Shift S" = File Project: Save As
"0" = Interface: Toggle Layer Panel
"1" = Layer: Exposure: Go to Previous Instance
"2" = Layer: Exposure: Go to Next Instance
"3" = Zoom: Scroll Down Right
"4" = Zoom: Scroll Left
"5" = Zoom: Center
"6" = Zoom: Scroll Right
"7" = Zoom: Scroll Up Left
"8" = Zoom: Scroll Up
"9" = Zoom: Scroll Up Right
"Ctrl Pad 0" = Zoom: 1-1
"Ctrl Pad 1" = TVPaint Animation: Room 1
"Ctrl Pad 2" = Tools Option: Move Down
"Ctrl Pad 3" = TVPaint Animation: Room 2
"Ctrl Pad 4" = Tools Option: Move Left
"Ctrl Pad 6" = Tools Option: Move Right
"Ctrl Pad 7" = TVPaint Animation: Room 3
"Ctrl Pad 8" = Tools Option: Move Up
"Ctrl Pad 9" = TVPaint Animation: Room 4
"/" = Tools Option: Decrease Rotation
"*" = Tools Option: Increase Rotation
"-" = Tools Option: Decrease Size
"+" = Tools Option: Increase Size
"," = Layer: Pick Layer
";" = Color: Color Picker
":" = Tools Option: reset
"!" = Timeline: Notes: Toggle
"<" = Zoom: Out
">" = Zoom: In
"~" = Zoom: Rotation Reset
"'" = Zoom: Rotation Reset
"|" = Interface: Toggle Coordinates Panel
"`" = Zoom: Rotation Reset
"[" = Zoom: Flip horizontally
"]" = Zoom: Flip vertically
"=" = Layer: Toggle Display All
"F1" = TVPaint Animation: Help
"F2" = Drawing Mode: 01 (Color)
"F3" = Drawing Mode: 02 (Behind)
"F4" = Drawing Mode: 03 (Erase)
"F5" = Drawing Mode: 04 (Panto)
"F6" = Drawing Mode: 05 (Merge)
"F7" = Drawing Mode: 06 (Shade)
"F8" = Drawing Mode: 07 (Light)
"F9" = Drawing Mode: 08 (Colorize)
"F11" = Zoom: Show full page
"F12" = Interface: Toggle windows display
"Shift F5" = Project: Clip: Delete Image
"Tab" = Project: Clip: Goto Next
"Shift Tab" = Project: Clip: Goto Previous
"Ctrl Tab" = Zoom: Next Zoom window
"Ctrl Shift Tab" = Zoom: Prev Zoom window
"Enter" = Shape: Apply
"Escape" = Shape: Cancel
"Home" = Layer: First Image
"Shift Home" = Zoom: Rotation Reset
"Ctrl Home" = Layer: First Layer
"End" = Layer: Last Image
"Ctrl End" = Layer: Last Layer
"Ctrl Shift End" = TVPaint Animation: Magic Number
"Del" = TVPaint Animation: Delete Selection
"Shift Del" = Shape: Erase Last Point
"Insert" = Zoom: Rotation Reset
"Backspace" = Layer: Clear
"Up" = Layer: Go Up
"Shift Up" = Layer: Go Up with Selection
"Ctrl Up" = Layer: Move Layer Up
"Ctrl Shift Up" = Bookmarks: Toggle
"Down" = Layer: Go Down
"Shift Down" = Layer: Go Down with Selection
"Ctrl Down" = Layer: Move Layer Down
"Ctrl Shift Down" = Color: Down
"Left" = Layer: Go Left
"Shift Left" = Layer: Go Left with Selection
"Ctrl Left" = Layer: Exposure: Go to Previous Instance
"Ctrl Shift Left" = Bookmarks: Previous
"Right" = Layer: Go Right
"Shift Right" = Layer: Go Right with Selection
"Ctrl Right" = Layer: Exposure: Go to Next Instance
"Ctrl Shift Right" = Bookmarks: Next
"Page Up" = Layer: Prev Key
"Shift Page Up" = Zoom: Rotate +15 (counter clockwise)
"Page Down" = Layer: Next Key
"Shift Page Down" = Zoom: Rotate -15 (clockwise)
Hotkeys.zip
(5.93 KiB) Downloaded 446 times
acrookedheart
I mistakenly posted this in the forum.
Windows 64
For the post, I removed the =none lines and left only the shortcuts in play.
Shortcuts
"A" = Zoom: Shake
"C" = Brush: Rotate
"D" = Shape: Stroke
"H" = Layer: Split
"K" = Brush: Resize
"Q" = Zoom: Out
"S" = Shape: Dots
"W" = Zoom: In
"Shift G" = none
"Shift M" = none
"5" = Zoom: Center
"<" = Zoom: Out
">" = Zoom: In
"Up" = Layer: Go Up
acrookedheart
Xavier wrote: 15 Dec 2021, 11:41
Windows 64
Shortcuts
"A" = Zoom: Shake
"C" = Brush: Rotate
"D" = Shape: Stroke
"H" = Layer: Split
"K" = Brush: Resize
"Q" = Zoom: Out
"S" = Shape: Dots
"W" = Zoom: In
"Shift G" = none
"Shift M" = none
"5" = Zoom: Center
"<" = Zoom: Out
">" = Zoom: In
"Up" = Layer: Go Up
Hotkeys.zip
(5.93 KiB) Downloaded 425 times
