Export to mp4 lossless - Error
Sewie
Post by Sewie »
I need to export my work to send it to an editor. For some reason TVPaint gives me the following error when I try to export to any of the mp4 lossless formats.
Anybody know what this is or how I can get my work exported to a lossless format?
(Btw, this also happens when I try to export to a lossless .mov format)
Sewie
Re: Export to mp4 lossless - Error
Post by Sewie »
Hi Shabazzy,
I'm not sure how to check which codecs are installed and how I can check if TVPaint sees them? I have installed a bunch of codecs over time, including the FFmpeg for TVPaint use, but I have no idea where the system - or TVPaint for that matter - put them...
I'm working with the latest version of TVP (11.5.3 ). I forgot to update my signature.
Sewie
Post by Sewie »
Thanks for the help, Shabazy.
I have no idea what codec TVpaint is not finding. With previous versions of TVPaint these exports worked fine so I suspect it's a TVPaint issue.
Could someone from the TVPaint team chip in, please...?
Hello Sewie, did the issue start occuring overnight or after updating TVPaint?
Could try creating an alternative user config in the Startup Panel (enabled from the Startup tab of the Preferences) and see if the issue persists with it, please?
Xavier
Post by Xavier »
Sewie wrote: 30 Dec 2021, 13:51 Hello,
Hi, I see you're using Windows : do you have any previous version of TVPaint installed ?
Sewie
Post by Sewie »
Dean wrote: 03 Jan 2022, 10:44 Hello Sewie, did the issue start occuring overnight or after updating TVPaint?
Hello Dean, I just tried with a new configuration from the Startup Panel and had the same error occur. If I remember well, but I'm not 100% certain of this, is that this problem started after the last update.
No, I just checked. Just the 64 bits of the latest version (11.5.3)
Xavier
Post by Xavier »
Ok, I'll double check tomorrow. In the meantime can you please give me the build date that is shown in the TVPaint's Help>About window ?
Sewie
Post by Sewie »
Thank you, Xavier.
The build date is: Oct 22 2021.
Xavier
Post by Xavier »
Have you tried downloading again ? I had to do a hotfix, the setup was updated silently.
Sewie
Post by Sewie »
Yes, I just reinstalled the same version (11.5.3 10173wo Pro (64 wibu)) and the error still shows up.
Xavier
Post by Xavier »
Indeed I reproduced it by my side, sorry. Do you have an old setup of TVPaint 11.0 ? if so, you should be able to export your project.
I'd need some time to understand what went wrong...
Sewie
Post by Sewie »
Thank you, Xavier. So it's a bug in the latest version, if I understand correctly?
I don't have any older versions installed, mostly to avoid conflicts between the various versions. (dongle vs dongleless for example) .
I'll find another solution, for now it's good to know that the problem is not on my end. :)
Xavier
Post by Xavier »
Yes, it's another bug to fix :cry:
Thanks for your understanding, I learn TVPaint internals by doing and some topics -like the codec support on Windows- are very touchy. It's a matter of properly cross-compiling FFmpeg and all its dependencies... the addition of MP4 / H.264 had side effects.
