the app closes when i sleep
MatthewPrower
Post by MatthewPrower »
idk about you, but every time i put my computer on sleep mode while tvpaint is running, the app suddenly closes for some reason
why's that?
Re: the app closes when i sleep
Hello Matthew, it happens on some systems and not on others, we are currently investigating this issue, but clues are scarce.
Other visual creatiion/editing apps are affected by this as well. It mights be linked to how the user's machine is setup to handle sleep mode.
On my 2 computers (Mac) this never happened with any app. My settings: after 15 min computer and monitor shut down, drives also if possible (means, if not busy).
Xavier
Post by Xavier »
MatthewPrower wrote: 21 Mar 2022, 10:28 idk about you, but every time i put my computer on sleep mode while tvpaint is running, the app suddenly closes for some reason
why's that?
First things first, we'd need to know which machine/OS/TVPaint version you use :)
MatthewPrower
the windows x64 version, on an insprion with a wacom tablet
Soom
Post by Soom »
good I never put my machine to sleep )
Regarding the sleep mode issue, some other users have it, but so far we haven't been able to determine what causes it.
It might be linked to the machine's power settings or some fix might be needed on WIBU's part. Anyway we will continue to investigate it.
In the meantime, we recommend that users save their project and close TVPaint before leaving their machine for a time long enough that it triggers sleep mode.
