JSON import leads to shortened compositions in AE
Posted: 26 Apr 2022, 15:25
Hello!
I have problems with JSON export from TVPaint to After Effects. Strangely, once I import (with the JSON script) the files into After Effects, the compositions become half the length they were in TVPaint. Then when I manually extend them in After Effects, the missing layers appear, but the keyframes are partially wrong and the wrong layers are visible. I am working with 12fps and the following specs:
OS: Windows 10, 64bit, 32 Gbit RAM, Intel Core i7-7700HQ CPU.
Software: TV Paint 11.5.1, Standard Edition
I have worked with JSON export before and it has always worked so far. Could it be due to the frame rate? Or has anyone had this problem before as well?
Best regards
Nina
Best regards
Nina
