Rearranging the frames/exposures around the same layer? Topic is solved
mittenkiss
Post by mittenkiss »
Hello everyone!
I'm new to TVPaint and I'm messing around with pose to pose. While I'm watching a tutorial, I didn't realize that I was drawing on the wrong frame, and I don't feel like having to copy and paste, or delete and redraw it, etc.
Is there anyway for me to drag the frame around the same layer?
Thank you
Re: Rearranging the frames/exposures around the same layer?
mittenkiss wrote: 10 Jun 2022, 05:49 Hello everyone!
Thank you
Yes. Select the image (or images) you want to move , click and hold on the image(s) and drag to where you want to move the image(s). When you release the image(s) you should see a pop-up with options: Move , Copy, Insert
https://www.tvpaint.com/doc/tvp11/index ... side-layer
https://www.tvpaint.com/doc/tvp11/index ... ther-layer
https://youtu.be/aMnhwTnxV8M
Hello, it is possible to drag a selection of instances on a layer:
Just select the instances you want to move around and drag them to their destination. If it it on a spot where other instances are present, the "insert" option is preferred to avoid replacing drawings in that area.
Edit: I see David already responded! :)
