New Project Configuration/Template Camera View not remembered
Usually I have my Start Up Preferences set to open the Start Up Panel. However, recently I wanted to open TVPaint from a pre-set Template or open from Last Configuration Used.
But when I open TVPaint with Last Configuration Used or from a Template it does not remember the settings correctly.
Here is what I do:
Create a New Project. Project with Camera view . 1920 x 1080 x 200% = 3840 x 2160.
create new project with camera view.jpg (23.8 KiB) Viewed 2854 times
It looks like this:
1080 camera view 3840x2160.jpg (43.52 KiB) Viewed 2854 times
Save As Template and name it 1080x2.
Now when I set my Start Up Preferences to Open From a Template and select this template (1080x2) I would expect TVPaint to open this template next time I start up TVPaint.
OR if I set TVPaint to Remember Last Used Configuration it should open this same set up.
However, when I open TVPaint the next time it opens a project size 3840 x 2160 with the camera view set to 3840 x 2160 , not a camera view of 1920 x 1080.
TVPaint did not open the saved Template. Or if I had it set to Remember Last Used Configuration the same thing happens: it opens a project 3840 x 2160 with the camera value reset to 3840 x 2160 not to 1920 x 1080. So the problem is that TVPaint does not remember the Template or the Last Configuration Used , because the last configuration used had the camera view set to 1920 x 1080 , not 3840 x 2160 .
Here is a screen capture video showing the problem:
https://drive.google.com/file/d/1nP0pNx ... sp=sharing
Xavier
Re: New Project Configuration/Template Camera View not remembered
Post by Xavier »
Indeed, I reproduced it with the 11.0.10 too :?
Here is another problem with TVPaint not remembering the template dimensions:
I create a New Project with Camera View of 1920 x 1080 , at 200% overscale , so the canvas size is 3840 x 2160 .
Create new project.jpg (22.91 KiB) Viewed 2809 times
Save as a Template named 1920x1080 Camera
save project as Template.jpg (91.46 KiB) Viewed 2809 times
Now create a New Project and select my saved Template 1920x1080 Camera:
Create New Project from Template.jpg (49.78 KiB) Viewed 2809 times
but instead of creating a new project with my template settings (3840 x 2160 canvas with a 1920 x 1080 camera view) it doubles the dimensions to create a new project with canvas size 7680 x 4320 and a 3840 x 2160 camera view, so it does not remember the camera view and canvas size dimensions of the saved Template.
Template dimensions are not remembered.jpg (29.76 KiB) Viewed 2809 times
Xavier
Post by Xavier »
Fixed ;)
For the record: the problem with the 'Save Project as Template' is not fixed in either version 11.7 or 11.7.1 .
What did get fixed is if you set the Start Up prefs to "Remember last used configuration" or "Template" , it will open up next time with the saved scene template , including the camera parameters. So it must be possible to save a template with the camera parameters, but it doesn't work if you use the Start Up panel and select a saved template from the Templates menu in the Start Up Panel. That is the problem.
