https://github.com/thenickdude/wacom-driver-fixWacom's macOS drivers for Bamboo, Graphire, Intuos 1, 2 & 3 and Cintiq 1st gen tablets have bugs in them that cause them to completely fail to start on macOS 10.15 Catalina and later versions (including 11 Big Sur and 12 Monterey). This doesn't apply to the Windows driver, or to the drivers for their newer tablets.
When you try to open the Wacom preference pane with a Bamboo tablet, you'll get an error message saying "Waiting for synchronization", then finally "There is a problem with your tablet driver. Please reboot your system. If the problem persists reinstall or update the driver". For an Intuos 3 or Cintiq 1st gen tablet, the preference pane will open, but clicking anything will cause it to crash with the message "There was an error in Wacom Tablet preferences." For Graphire and Intuos 1 & 2 tablets, the driver's installer couldn't even run on Catalina.
Thankfully I was able to track down the issues and I have patched the drivers to fix them!
Fixed MacOS Drivers for older Wacom tablets
Wacom Bamboo, Graphire, Intuos 1+2+3 and Cintiq 1st gen tablet drivers for macOS Catalina, Big Sur, Monterey (including M1 Macs) .
Re: Fixed MacOS Drivers for older Wacom tablets
Though I'm not a mac user I found thenickdude's GitHub offering fascinating: He seems to know his way around the Wacom drivers and (after some disassembly, discovered a few wrong values in unpublished fields of Apple's "private" API).
Apparently, he now offers a variety of patched drivers for various Wacom tablet devices that suddenly work (after he tweaked a byte or two in the code). He also suggests simple swap-in installation directions. In return he requests a modest tip.
His short detective story (and mystery solved-fix) is worth a read...
David, I'm curious whether you tried out any of the replacement drivers?
sven
sven
Thanks David !!!
