How to remove this rectangle layer ?
Posted: 09 Aug 2022, 20:43
by airman
Hello
I tried for almost a day to remove this, looked upon google to do so (couldnt find )
I need help to remove this layer with the purple rectangle there please !
Re: How to remove this rectangle layer ?
Posted: 09 Aug 2022, 20:51
It looks like a camera view. Turn it off in Display Settings. (uncheck the box next to Camera)
First image shows the camera view ON. Second image shows it turned OFF in Display settings.
Camera view turned on:
Camera view turned off:
Or in the Camera tool select "Reset and Fit to Project" -
- Screen Shot 2022-08-09 at 4.53.37 PM.png (23.73 KiB) Viewed 4295 times
On your screenshot it looks like the Camera setting on your project is an irregular aspect ratio , so you will also want go into the Camera Parameters and reset it to 'No Conversion' , so the camera view is exactly the same as the project size.
Posted: 09 Aug 2022, 21:17
by airman
Oh sorry i use tvpaint 10
Posted: 09 Aug 2022, 21:21
by airman
I managed to make it right !
Its here
I removed the camera, yes it was the camera !
Thanks very much @D.T. Nethery
Its solved
Posted: 09 Aug 2022, 22:14
airman wrote: ↑09 Aug 2022, 21:21
Its here
Its solved
Glad that it helped ! I did notice you were using TVPaint 10. The Display Settings are more or less the same in TVPaint 10 as in TVPaint 11, but I should have posted a screen shot noting the difference. But you figured it out anyway , so all's well.
Just in case someone else is looking through the forum trying to solve the same problem at some point in the future , here are the screenshots from the TVPaint 10 User Manual showing the settings in TVPaint 10 -
- TVPaint_10_Camera_Display_Settings.png (65.11 KiB) Viewed 4275 times
