Set all layers to Hold|Ping-Pong|None|Repeat
cgmodeler
Post by cgmodeler »
Just did this small script that sets all the layers for the current clip post behavior as none, repeat, ping-pong or hold
It has a little window to write the desired post behavior.
It will store it as a variable for the next session so you can run it quickly
Eg. If I want all layers on the current clipto be HOLD, I write "hold"
LayerPostBehavior.tvpx
(55 KiB) Downloaded 1597 times
Param None
tv_readUserString "postBehaviorVar" "postBehavior" Hold
parse result postBehavior
tv_reqstring "Input the mode for all layers none, repeat, ping-pong, hold |"postBehavior""
IF (CMP("Cancel",postBehavior)!=1)
	tv_writeUserString "postBehaviorVar" "postBehavior" postBehavior
END
PARAM none
layerCount = 0
loop2 = 1
WHILE loop2
tv_LayerGetID layerCount
currentLayerID = result
IF CMP(currentLayerID,"none") == 1
loop2 = 0
ELSE
tv_LayerSet currentLayerID
tv_layerpostbehavior 0 postBehavior
layerCount = LayerCount + 1
END
END
www.cocoalopez.com
NathanOtano
Re: Set all layers to Hold|Ping-Pong|None|Repeat
Post by NathanOtano »
Useful thanks! :)
