Delete Empty Layers in 11.7.0?
Sewie
Post by Sewie »
Just downloaded and tested the 11.7 update. The new Delete Empty Layers option seemed promising in managing my files and projects.
But it seems that I am missing something or doing something wrong. In the Main Menu when I select: Layers > Delete All Layers > Empty Layers nothing happens. What's up with that? Is it me...?
Layers > Delete All Layers > Inactive Layers works fine with me, though...
Sewie
Re: Delete Empty Layers in 11.7.0?
Post by Sewie »
Delete Empty Layers seems to work fine now. Pardon me.
Don't know what changed, though...
I rebooted this morning so that might be it. But then I also rebooted a few times when I tested 11.7.0 last night...
Xavier
Post by Xavier »
Sewie wrote: 22 Sep 2022, 21:04 Hello,
Hi, not sure of what occurs here, would you mind sharing a sample project ?
The notion of emptiness for a layer is maybe to refine.
Xavier
Post by Xavier »
Sewie wrote: 23 Sep 2022, 09:07 Delete Empty Layers seems to work fine now. Pardon me.
So far a layer is considered empty if all its instances are completely blank. Maybe you had some remaining pixels.
Sewie
Post by Sewie »
I don't think so. I tested it by creating a bunch of empty layers and then trying to delete them trough the new option.
Maybe I should reset my TVPaint configuration to factory setting and start over. There might be a bunch of leftover code or George script, collected throughout the years, floating about in the software that might be causing conflicts...
Would you know how I can do a reset of TVPaint?
Xavier
Post by Xavier »
Sewie wrote: 23 Sep 2022, 09:17 I don't think so. I tested it by creating a bunch of empty layers and then trying to delete them trough the new option.
There may be an issue, that's why I was asking you a sample project which fails when deleting the empty layers
Xavier
Post by Xavier »
Sewie
Post by Sewie »
Xavier wrote: 23 Sep 2022, 09:19
I see, I' send one later today. Where to address it?
Xavier
Post by Xavier »
Sewie wrote: 23 Sep 2022, 09:21
Thanks, I reproduced the issue with your project. There's a bug !
Sewie
Post by Sewie »
Thanks!
Good to know I could help to squash it then. :)
Xavier
Post by Xavier »
Sewie wrote: 26 Sep 2022, 09:45 Thanks!
I think I fixed it. The update will be published ASAP (but not today). Thanks for the report !
Hi Sewie,
Today's hotfix should have fixed this: https://forum.tvpaint.com/viewtopic.php ... 25#p130925 :)
Sewie
Post by Sewie »
Great!
Thank you.
