Hi there,
This might also happened to me a couple of times before in TVPaint 11.5.3 but TVPaint 11.7.0 has crashed a couple of times when duplicating multiple layers.
Details about my setup can be found in my profile description.
Is this a known issue?
TVP 11.7 crashes sometimes when duplicate layer Topic is solved
TVP Pro 11.7.1
TVP Pro 11.7.1
Re: TVP 11.7 crashes sometimes when duplicate layer
Hi Joost,
Can you record a video of the issue happening, or send us a project where this is happening ?
On sick leave until July 8th
It only happens very occasional. And I can't reproduce it...
As soon as it happens again, I will try to send you some details/proof!
TVP Pro 11.7.1
TVP Pro 11.7.1
So far we haven't seen this. I tested on a Mac Mini M1 and TVPaint didn't crash even when duplicating multiple layers, sorry.
I am also currently running tests on an Intel iMac but wasn't able to reproduce the problem either.
Is it happening with different projects or did the crashes occur when you were working on a particular file?
It never crashed again after my last post. So maybe my mac had just a bad day
I will keep you posted if it ever occurs again.
TVP Pro 11.7.1
TVP Pro 11.7.1
That's good to hear! It happens sometimes, yes
