How do you make shortcut for select row view/column view/ timeline view in the project window?
Markxu
Post by Markxu »
I really like to have shortcuts where I can switch in between timeline view and thumbnail view in the project window, (since I need to constantly check the timing and the shots) however I can't find anything related in the actions or George script.
I am using the professional version 11.52.
Mark.Mou
Re: How do you make shortcut for select row view/column view/ timeline view in the project window?
Do you mean timeline / clip view?
I don't think a shortcut or george option will toggle between timeline view and thumbnail view... maybe a request is in order...
sven
Markxu
Post by Markxu »
slowtiger wrote: 03 Nov 2022, 08:48 Do you mean timeline / clip view?
No, the timeline style view inside the project window, as well as the vertical style row view and the column style view
Mark.Mou
mox
Post by mox »
Not sure if it's what you're asking for? To switch from the Project tab to the Clip timeline tab, try: edit > shortcuts > in the Timeline list, assign Switch to Next Tab
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
Markxu
Post by Markxu »
mox wrote: 03 Nov 2022, 14:30 Not sure if it's what you're asking for? To switch from the Project tab to the Clip timeline tab, try: edit > shortcuts > in the Timeline list, assign Switch to Next Tab
I mean the 4 types of thumbnail view that are inside the project window
Mark.Mou
mox
Post by mox »
It seems you can't do it right now...
Jerome Lorin
Moxica (playground)
