CTG Layer - space in between colours is white but can't remove?
Posted: 12 Dec 2022, 22:10
by garthlaidlaw
Hi there,
I am using CTG layers for the first time and can't understand why there is a white space filling in between coloured elements. I have tried to erase multiple times and it's not working. No idea how it got there in the first place. It is on this frame, frame 61 and 64 and 67.
I'm sure this is an easy fix but I can't figure it out.
https://postimg.cc/YhLgwQ4Z
Garth
Re: CTG Layer - space in between colours is white but can't remove?
Posted: 12 Dec 2022, 22:27
Without seeing the tvpp file I can't know for sure, but I wonder if it is possible the line art layer has a white fill color in that area? (so using the CTG Exclusion stroke in that area would have no effect to erase it)
Posted: 12 Dec 2022, 22:35
by garthlaidlaw
Thanks for responding!
Nope, only the CTG layer is active other than the background here, and this is what it looks like. No checkerboards in between the legs.
Posted: 12 Dec 2022, 22:39
by garthlaidlaw
Okay, somehow it has fixed itself in other frames, but this one is now brown, and I can't erase it. What is with these CTG layers - why doesn't the eraser work?
Posted: 12 Dec 2022, 22:52
Can you draw an Exclusion Squiggle stroke in that area to prevent it from being filled with any color?
Screen Shot 2022-12-12 at 5.51.04 PM.png (18.39 KiB) Viewed 2544 times
Posted: 12 Dec 2022, 22:56
by garthlaidlaw
Hi! Thanks for the response. You posted this at the same time I managed to find this in the documentation.
Why doesn't the eraser simply act as an exclusion when there are no other squiggles in a given space, I have no idea. Feature request!
Thanks,
Garth
Posted: 13 Dec 2022, 09:32
by Dean
Hello Garth, this is because the user could want to add color in that zone later, so they would then need to use the eraser to erase the exclusion squiggle, but since there is no color around, should the eraser just add more exclusion?
It seems simpler to have 2 separate tools for these tasks.
Posted: 13 Dec 2022, 16:47
by garthlaidlaw
Hey Dean - you're right. It would be much easier to have a separate tool for "painting" transparent areas. Good point!
