Reproduction error Topic is solved
MarierV
Reproduction error
Post by MarierV »
Hi!
I've been working on some animations these past couple of days, but today I tried hitting play to one of them, and it doesn't reproduce the canvas area as it should. I re-downloaded TVPaint just in case, but it still plays the canvas area the same, ignoring rotation too.
The version I have is TVPaint 11.7.1 on MacOs Ventura 13.3.1 (64 bits).
Reproduction error in TVPaint.mp4
(11.56 MiB) Downloaded 276 times
Reproduction error #2.mp4
(16.71 MiB) Downloaded 281 times
Re: Reproduction error
Hello, from what I understand, the playback uses the camera angle you previously set but you wish it didn't.
This can be disabled using this button on the timeline's remote area:
Dean wrote: 22 May 2023, 07:28 Hello, from what I understand, the playback uses the camera angle you previously set but you wish it didn't.
In addition to turning off the Playback with Camera View , you may also reset the Camera View in the tool panel (but only do this if you will not use the camera settings again; if you want to keep the camera settings then simply disable the Playback with Camera view as Dean suggested).
TVPaint Reset Camera.png (34.59 KiB) Viewed 3786 times
MarierV
Post by MarierV »
I see, I must have accidentally clicked on the button and didn't realize it. Thank you! I'll keep the settings in mind next time c:
