import png with transparency
Posted: 31 May 2023, 08:40
by hellofilms
HI,
When I import png there is no transparency even if there was when exporting it from Clip Studio Paint.
What could be the problem?
/Mattias
Re: import png with transparency
Posted: 31 May 2023, 15:49
Wrong export from CSP. Check the settings there.
Posted: 31 May 2023, 19:10
hellofilms wrote: ↑31 May 2023, 08:40
HI,
/Mattias
slowtiger wrote: ↑31 May 2023, 15:49
To build on Slowtiger's answer , did you turn off the white "paper" background in CSP ?
Here are the settings I used for exporting a transparent PNG from CSP . It works fine when imported to TVPaint.
(click on images to view full size)
Imported to TVPaint -
Posted: 31 May 2023, 19:31
by hellofilms
Thanks for your answers.
I did some testing.
I use the same settings you have in CSP. I have done this many many times and it always worked.
I tested to when importing into TVpaint to change "alpha" to PreMult. even if I got a warning window saying that this setting is not recommended for this kind of image, But then the transparency worked.
Strange.
But Glad I found a way to do it finally.
Posted: 31 May 2023, 20:56
hellofilms wrote: ↑31 May 2023, 19:31
I did some testing.
I tested to when importing into TVpaint to change "alpha" to PreMult. even if I got a warning window saying that this setting is not recommended for this kind of image, But then the transparency worked. Strange. But Glad I found a way to do it finally.
Interesting. I get the same results when importing the PNG from CSP to TVPaint , whether I have the Import window in TVPaint set to PreMultiply or No PreMultiply. (I did get the warning pop-up, but it made no difference in the image that was imported).
- Screen Shot 2023-05-31 at 3.57.20 PM.png (93.52 KiB) Viewed 2165 times
Posted: 01 Jun 2023, 06:24
by hellofilms
Hi,
Strange.
At first when it did not work the Alpha was set to "Guess". I thought TVpaint would see the ttransparency but it did not. So I had to set it to "PreMultiply".
