tv_version "username" Topic is solved
MightyNice
Post by MightyNice »
Hi,
In the docs, it mentions that
may be empty.
It is empty when I use this command on my mac, but returns username fine on windows. I want the username so that I can create files/folders in /Users/<username>/Documents on my mac.
Is this possible?
thanks
Jeremy Richard
Re: tv_version "username"
Post by Jeremy Richard »
As an alternative you could maybe use tv_getpath?
tv_getpath home
tv_warn RESULT
tv_getpath home shows,
  • on Windows: C:\Users\MyUsername\Documents
  • on macOS: /Users/MyUsername
  • on Linux: /home/MyUsername
To have something like this (not tested):
tv_getpath home
user_directory = RESULT
export_path = user_directory"/Documents"
MightyNice
Thank you so much! That works!!
cheers,
Jason
