Hello, just wondering if there's a fix for this issue I'm having so I can get my notes back.
I've recently updated TVP to the latest version and migrated all my stuff over to a new mac (M1 Max, Ram 64GB, Ventura 13.4) I'm having trouble with only the moved files and not any new ones I create now.
I took a screenshot video to show exactly what's going on but I'm not sure how to post it easily on this forum so here's a drive link instead
https://drive.google.com/file/d/14ILTAv ... sp=sharing
Any way I can get my notes back?
Another thing I was going to ask about was my audio was uneditable and unmuteable (it would visibly look edited, but nothing sound changed on playback or by timeline scrubbing - even if I deleted all the sound) since the file migration, but as soon as I enabled sound via quicktime's screen recording it was resolved! I couldn't believe it.
I thought I'd add that here in case it helps anyone else out. Quicktime's always been the route of my audio problems with TVP.
Scribbly notes panel in timeline super glitchy, colourful pixelly static.
- melaphant3
Re: Scribbly notes panel in timeline super glitchy, colourful pixelly static.
Hello could you check if the issue persists with a fresh configuration file, please?
First, you might want to backup your custom brushes and shortcuts:
https://www.tvpaint.com/doc/tvp11/index ... m-settings
The config file is located in Library > tvp animation 11/pro > default > config.ini (I suggest you backup your current config.ini somewhere or rename it to "config_" so TVPaint creates a new one at launch).
But the system Library folder is hidden by default on MacOS, you can follow this guide to reveal it:
https://crunchify.com/have-you-noticed- ... os-x-lion/
- melaphant3
Thanks for waiting Dean
Just had a chance to try that and it still does it, unfortunately.
Sometimes I tumble : D
http://melaphantastic.tumblr.com/
Oh that's too bad. Are you using a Retina screen?
- melaphant3
Ah, yeah I am. I can't test it on a regular one unfortunately, but I bet that's it!
Oh well, some of my notes do still show up if I get in really close. That'll have to do it for me, haha. At least it's pretty.
- dmceachern
I'm having the same issue on my Mac Studio M1 Ultra, 128 gb, Ventura 13.5.1 with Wacom Cintiq Pro 24, though I have TV Paint launching in low res mode. Is there anyway to fix this or is it a bug of some sort? Also is there any word on a native ARM version of TVPAINT for Macs? Things run fine for the most part but I do occasionally find things a little laggy which I assume is the emulation.
A native ARM build of TVPaint is currently under development
- dmceachern
Awesome to hear! Thanks!
