Projects not visible after importing custom config
Soom
Post by Soom »
At work on TVP 11.7.1 STD my PROJECTS panel is totally empty (see screenshot) after I import the config from my home computer (which is a Mac and it's TVP 11.7.1 Pro). If I switch to default config, everything is fine again.
I tried going into the config.ini file, as I would usually do when something like this happens, but I cannot find the setting for this specific problem.
Anyone know how to solve it without having to reconfig everything from scratch again?
thanks!
Screenshot 2023-08-01 141316.png (16.17 KiB) Viewed 1783 times
Matthieu
Re: Projects not visible after importing custom config
Post by Matthieu »
Hello Soom,
Some issues may indeed occur when replacing either config. file since they differ between the Standard and Professional Editions. I am not sure we'd be able to pinpoint which combination of settings in the Professional Edition could lead to such a problem in the Standard Edition but someone else may have an idea...
