Can you "clear" the white area of an imported jpeg?
BruceM
Post by BruceM »
I've imported a jpeg of a title card. I'm resizing the card to look like a pullback and I want to use the light table to inbetween the positions. The problem is that I can't see through to the type font to inbetween it. The white area around the type is blocking my view. Is there a way to "clear" the white area so that the type becomes visible using the light table?
Re: Can you "clear" the white area of an imported jpeg?
Image > Basic Scan Cleaner. See manual for more options.
BruceM wrote: 01 Sep 2023, 03:11 I've imported a jpeg of a title card. I'm resizing the card to look like a pullback and I want to use the light table to inbetween the positions. The problem is that I can't see through to the type font to inbetween it. The white area around the type is blocking my view. Is there a way to "clear" the white area so that the type becomes visible using the light table?
FX Stack > Color > Scan Cleaner Black and White -
https://www.tvpaint.com/doc/tvp11/index ... lack-white
Or as Slowtiger mentioned, just use the preset version of Scan Cleaner from the Image menu. There are actually two Presets: Scan Cleaner (Soft) and Scan Cleaner (Stronger)
Screen Shot 2023-09-01 at 8.31.44 AM.png (60.02 KiB) Viewed 1637 times
Another option for what you are describing is to use the Magic Wand Selection Tool to select all the white area around the Type , then click on Delete , which deletes all the selected white area.
Screen Shot 2023-09-01 at 8.36.35 AM.png (62 KiB) Viewed 1634 times
Screen Shot 2023-09-01 at 8.36.49 AM.png (71.83 KiB) Viewed 1634 times
But Scan Cleaner is probably easiest for what you need to do.
BruceM
Post by BruceM »
Thanks DT and Slowtiger! The scan cleaner worked great!
