OTANO Guide Tools
NathanOtano
OTANO Guide Tools
Post by NathanOtano »
Hey all :) it has been a while
Here is a small set of scripts I like a lot! I recently updated it for my personal use and I think it's ready to be shared
OTANO Guide Tools v01.tvpx
(311.5 KiB) Downloaded 493 times
- Image guide swap : An old script I used to toggle visibility between multiple guide images. I use it to flip model sheets and diverse references above my animations which is more handy than using layers
- Vanishing point swap : I added an alternative to toggle visibility AND assist between multiple 1 point vanishing point (I much prefer multiple 1 point vanishing points than using the 3 pt guide). Useful to quickly work with multiple VP
- Brushsave to Guide : Choose a folder to save current brush, then it is added to your project as an image guide
I also quickly put there the "global display toggle" and "edit guides" shortcuts on two buttons because a lot of animators don't know about those function.
Re: OTANO Guide Swap Tools
very nice! thanks for sharing!
NathanOtano
Re: OTANO Guide Tools
Thanks peter <3
Quick update : I added a function i wanted for a while to be able to quickly add current cutbrush as image guide. It needs to be saved as an image on your computer
Would be nice to be able to do it directly without saving a file to embed it to the project but it is currently not possible with george scripts (i think?)
tribute27
Post by tribute27 »
These are amazing! Thank you for making and sharing them!
NathanOtano
nehavilash
Post by nehavilash »
Thaks for information.
