Preview playback function problem
Soom
Post by Soom »
In previous versions of TVPaint when I was pressing SPACE, the playback would start from current frame. Then if I press SPACE again it would pause. Then if I was pressing SPACE again, the playback would start from the beginning of the shot. It was actually a very convenient way to preview the shot with both methods by using only one shortcut. In the new versions there is a separate shortcut for each playback function, which makes it more cumbersome now. I cannot setup SPACE to be both a playback from current frame, and both playback from beginning of a shot. On MAC I cannot even add any more shortcut combinations to SPACE: CTRL+SPACE doesn't work, CMD+SPACE doesn't exist. The only other shortcut I can use is SHIFT+SPACE and that's what I am using for the other option, but it is really not convenient in terms of keyboard ergonomics...
Is there a way to go around it or should I post this as a feature request (to bring back a once existing feature :)) ?
